FC3S problem/need help....PLEASE!!
This is a discussion on FC3S problem/need help....PLEASE!! within the TECH Discussion Forum forums, part of the TECH Discussion category; I have a 87 N/A FC and everytime I give it more than 1/4 throttle it causes the engine to ...
Old 08-13-2005, 06:42 PM   #1
Kenjithelonely1
Kenjithelonely1's Avatar
I have a 87 N/A FC and everytime I give it more than 1/4 throttle it causes the engine to loose power and cut out around 3800RPM, then when you let off it makes a loud backfire. This problem seriously impairs the car and almost prohibits it from being daily driven. We have replaced the air filter, mass airflow sensor, spark plugs, wires, and the leading and trailing coils. If any rotary experts out there have any suggestions, anything would help, thanx.
Kenjithelonely1 is offline   Reply With Quote
Old 08-16-2005, 03:38 PM   #2
SpeedMachine
SpeedMachine's Avatar
So at 3800 it will cut out, or if you give it throttle over 1/4 before 3800 it will cut out? Secondaries are stagging at around 3800, so there could be something wrong there.
SpeedMachine is offline   Reply With Quote
Old 08-19-2005, 04:00 PM   #3
eyecandy
eyecandy's Avatar
Send a message via AIM to eyecandy
I thought 4K is when the secondaries come online, whether or not thats the case, the fact that its at a quarter throottle means it probably something else. I would have to say its your TPS, and then a possible dashpot with engine decleration. Last thing I can think of is a bad ECU.
I asume this is stock?
eyecandy is offline   Reply With Quote
Old 08-19-2005, 04:28 PM   #4
Drift Alliance
Tony Angelo
Drift Alliance's Avatar
sounds like secondary stumble, check your grounds sucka!
-Don't forget the struggle. Don't forget the streets-
www.driftalliance.com
www.clubloose.com
Listen to Motley Crue
Drift Alliance is offline   Reply With Quote
Old 08-19-2005, 05:48 PM   #5
SpeedMachine
No, they stage at 3800 rpm. I highly doubt anything with the dashpot, since I have never seen one go bad. Maybe out of adjustment, but the odds of that and the TPS at the same time are slim to non unless someone has dicked with the settings.
S4 TPS's are only 1/4 throttle units anyway, so over 1/4 throttle, the engine is getting no further signal changes from the TPS until it goes lower than 1/4. That is why I asked him if it was at 3800 it will cut out, or if you give it throttle over 1/4 before 3800 it will cut out.
Either way, I doubt he cares since I asked that 3 days ago and he never replied.
Grounds could be a role as well. Good re-grounding, cleaning the injectors and throwing the stock ECU in the trash will usually cure stuff like this
