TRanny Qustioins
This is a discussion on TRanny Qustioins within the TECH Discussion Forum forums, part of the TECH Discussion category; Dose anyone here know the differance between the s20 tranny and the ka tranny...My sr tranny craped the bed I ...
Old 09-07-2005, 09:05 AM   #1
EasTSide DRiFto
GoT DRIFT?
EasTSide DRiFto's Avatar
TRanny Qustioins
Dose anyone here know the differance between the s20 tranny and the ka tranny...My sr tranny craped the bed I think. So I am putting in the ka tranny. I was told all i have to do is change the bell housing and it should work., But I want to know the differance between the two. Thanks GUys.
EasTSide DRiFto is offline   Reply With Quote
Old 09-07-2005, 04:43 PM   #2
backroadTOUGE
backroadTOUGE's Avatar
Send a message via AIM to backroadTOUGE
if im not mistaken, the only real difference in the two trannys is in the sorter geared ka, for obvious nonturbo reasons. otherwise, im to belive they both can bolt right up with lil modification
backroadTOUGE is offline   Reply With Quote
Old 09-08-2005, 03:04 PM   #3
sdtouge
sdtouge's Avatar
keepbell housings swap tranny
Old 09-09-2005, 04:34 AM   #4
EasTSide DRiFto
GoT DRIFT?
Just some info. I was looking at the gear ratios between the ka and the sr. They are the same the only differance is that the ka 5th gear is longer then the sr.More TOP SPEED and drifting.!!!! Thanks again.
Old 09-09-2005, 06:27 AM   #5
ZoltecRules
ZoltecRules's Avatar
Send a message via AIM to ZoltecRules Send a message via Yahoo to ZoltecRules
Uhh, when do you ever plan on drifting in 5TH GEAR??
ZoltecRules is offline   Reply With Quote
Old 09-09-2005, 12:02 PM   #6
sdtouge
sdtouge's Avatar
ya how does a longer 5th gear mean more drifting
Old 09-14-2005, 09:56 AM   #7
EasTSide DRiFto
GoT DRIFT?
Ahhh....If you read what I said I said more top speed and drifting, Thus meaning the car will have a higher top speed and i will still be able to drift in the lower gears the same as my sr tranny, Not high speed drifting in 5th gear.
Old 09-14-2005, 07:45 PM   #8
dreamdrivedrift
i see, but theres a 5th gear speed limiter if i remember correctly...so might wanna remove it. I'm not sure if its in the transmission housing or the diff, anyone who knows post up on that?
dreamdrivedrift is offline   Reply With Quote
Old 09-14-2005, 09:43 PM   #9
sdtouge
sdtouge's Avatar
its on the tranny check out the fsm. i dont really suggest driving that fast tohugh.
