performance camshaft question
This is a discussion on performance camshaft question within the TECH Discussion Forum forums, part of the TECH Discussion category; okay, so in the near future i plan on dropping in a new camshaft. here are my options... Grind: 17030. ...
Old 09-25-2005, 05:32 PM   #1
sukimoto
1979 Datsun 280zx
sukimoto's Avatar
Send a message via AIM to sukimoto
Grind: 17030. Lift(In/Ex): .460/.460. Duration(In/Ex): 260/260. Characteristics: Moderate idle, good power 1500-5000 RPM.
Grind: 17033. Lift(In/Ex): .480/.480. Duration(In/Ex): 274/274. Characteristics: Good idle, power range 2000-6000 RPM. Great slalom grind, works well with stock carbs or triple Webers.
Grind: 17034. Lift(In/Ex): .460/.460. Duration(In/Ex): 270/280. Characteristics: Rougher idle, excellent performance. Pulls hard from 3000-6500 RPM.
which would be best for drifting?
sukimoto is offline   Reply With Quote
Old 09-28-2005, 01:15 PM   #2
TireFrier
you might want to call motorsport and see what they reccomend with the L28 with EFI... certain cam choices might not work well with the factory fuel injection system.
TireFrier is offline   Reply With Quote
Old 09-28-2005, 01:21 PM   #3
road-star2696
road-star2696's Avatar
Smile powerband range
wherever your power band is on your engine is pretty much where u should be drifting so you would want the cam that fits that range best.
road-star2696 is offline   Reply With Quote
Old 09-29-2005, 09:36 AM   #4
sukimoto
1979 Datsun 280zx
sukimoto's Avatar
okay, i have a list of necessary replacements when changing camshafts, but which should i choose for drifting/daily driving. i can handle a harsh ride
