Need advice on tires
This is a discussion on Need advice on tires within the TECH Discussion Forum forums, part of the TECH Discussion category; My car: 92 240sx hatch aprox 250whp 2430lbs without me in it this car is solely my compeition car. im ...
Old 10-17-2005, 04:00 PM   #1
HoosierDrifter
Question Need advice on tires
aprox 250whp
this car is solely my compeition car. im still amature status... but i do not want a beginners setup. right now i have only 17x7 rims all around. so max width i can run is 225..which i have on there now. my fronts are all season 215/40-17s...rears are crapped out 3 season 225/45-17s... i noticed i cant get any angle worth a *Censored**Censored**Censored**Censored* when drifting and i just spin out.. i think this is because of my crappy rear tires.
since i need rear tires.. im gonna get some good ones for the front too. im going to stick with 215/40s on the front and 225/45s on the rear. my question is... should i go with summer ultra high performance tires all around? or should i go with a less grippy tire for the front or rear or all 4. i have a really tight budget so.. im probably going to go with sumitomo's or somthin cheap. any advice concerning tires would be great.
thanks,
-Dustin
HoosierDrifter is offline   Reply With Quote
Old 10-17-2005, 04:21 PM   #2
dreamdrivedrift
i haven't heard any bad things about falken azenis rt-615s, so maybe you can give 'em a shot
dreamdrivedrift is offline   Reply With Quote
Old 10-17-2005, 04:33 PM   #3
my 1 88 u
my 1 88 u's Avatar
azenis st115
Old 10-19-2005, 10:25 AM   #4
sleedawg
Dustin,
A lot of your tire selection would also depend on your suspension setup, but a good setup is stick up front and cheapy tires out back with the whp rating you have.
A tire selection that a lot use of people use are...
Falken Azenis RT-615 up front for grip
and
Falken ST-115 in the rear to get sideways
or cheaper alternative
Falken ST-115 in the front
and
Falken 512 Ziex
One thing to consider is the 512 Ziex do get eaten up quickly, but do help the car get sideways.
sleedawg is offline   Reply With Quote
Old 10-19-2005, 11:43 AM   #5
RED350z
RED350z's Avatar
I had really good luck with the AVON tech M500's, they are cheap, like $100 each and they smoke really well and hold up to abuse great. Ive had about 4 sets on the back of mine and they do well for the money and i have never had any bad blowouts as of yet. Another good part is they are sticky enough to run up front to. Great all around tire my the money...
RED350z is offline   Reply With Quote
Old 10-19-2005, 12:19 PM   #6
HoosierDrifter
Originally Posted by sleedawg
Dustin,
and
and
Falken 512 Ziex
well... im not an expert yet but, i think having a really sticky tire up front and a less grippy rear tires would cause the car to spin out at high angles. i said earlier that my rear tires are crapped out... yea i can get sideways easy,but if i get any kind of good angle... she just goes around on me. By having a higher grip rear tire, i beleive you can get more angle without spinning out due to the fact when you let off , they will gain traction better.
btw - im running tein flex coilovers right now
Old 10-19-2005, 04:15 PM   #7
Piner
Piner's Avatar
well the spinning out isnt the cars fault....
Old 10-19-2005, 06:19 PM   #8
silver_beast
silver_beast's Avatar
Send a message via MSN to silver_beast Send a message via Yahoo to silver_beast
I could vouch for that
silver_beast is offline   Reply With Quote
Old 10-19-2005, 07:22 PM   #9
110octane
110octane's Avatar
Falken ST-115's offer plenty of grip for your horse power and they are affordable. You will appreciate the level of grip and lifespan for the money. You can buy cheap tires all day long but if the grip isn't there and they wear fast they end up costing more in the long run. Just my .02
110octane is offline   Reply With Quote
Old 10-19-2005, 09:06 PM   #10
HoosierDrifter
yea... its my heavy foot
Old 10-19-2005, 10:45 PM   #11
silver_beast
or someone getting e-brake happy and holding it locked to long
Old 10-20-2005, 07:52 AM   #12
sdtouge
sdtouge's Avatar
im also guessing 250hp in that light car isnt helpling when your still learning.
Old 10-20-2005, 10:40 AM   #13
D1 DRIFTER
D1 DRIFTER's Avatar
my advice u have decent horsepower so a sticker tire should be a must anyways wether your learning or not that way you are learning it with bettertires... they help me and yea they can help with drifting but not pursay angles thats all driver and steering/inputs well good luck i recommecnt rocking cooper zeon zx2 they smoke well and last very long actually
Old 10-20-2005, 01:14 PM   #14
BenR
BenR's Avatar
I run thoes same tires Cooper Zeon 2XS in a 215/40/17. My car is an S13 with similar power and weight. The Coopers take the heat really well, much better than alot of other tires that I've run that seem to just delaminate and fall apart before the rubber is gone. They smoke just fine.
Your spin problem may be setup related or driving. But it's really hard without knowing exactly what your setup is. Sticky tires will help though.
BenR is offline   Reply With Quote
Old 10-20-2005, 02:10 PM   #15
Mike Peters
that is true, the 2xs tires do handle heat very well and are very consistent, they dont smoke as much as i would like compared to other tires but as much as i have tried all season the 2xs tires have all worn without chunking pretty much to the chord.
Old 10-24-2005, 01:22 PM   #16
USDRFTR
What differential are you running? open, lsd, clutch type, welded?
USDRFTR is offline   Reply With Quote
Old 10-24-2005, 02:16 PM   #17
akuma S14
akuma S14's Avatar
Send a message via MSN to akuma S14
Cooper Tires are #1
akuma S14 is offline   Reply With Quote
Old 10-25-2005, 06:28 PM   #18
HoosierDrifter
vlsd
coopers huh... i hope you guys arent just telln me this to advertise for them
Old 10-25-2005, 07:52 PM   #19
Mike Peters
even though im "sponsored" by cooper when i say they are extremely consistent, last a decent while and dont smoke im not lying. however if i said they were grippy or the best tire for drifting that would be an all out lie, but for the price they are awesome, due to the sheer cheapness, and they are very very very consistent, but wont offer the smoke/grip of some other tires. but thye are very very very consistent, and will last a good while. grip is good for a 280 treadwear tire and the 3 ply sidewall results in good turn in etc etc. but again its a 280 treadwear tire so the grip isnt crazy sticky like azenis/R's would be, adn they dont smoke a ton.
Old 10-25-2005, 09:09 PM   #20
HoosierDrifter
all those "verys" are maken my eyes hurt lol. why would you care about the amount of smoke? i dont need somthin mega sticky... but for my rear tire width only being 225mm maybe i will need somthin stickier. i will definately look into coopers.. they sound like a good "intermediate" tire... which is exactly what i need. Thanks for all of your advice guys.
Old 10-25-2005, 09:51 PM   #21
D1 DRIFTER
D1 DRIFTER's Avatar
best of luck man but ur best bet is to play around with tires shoot even try to pick up used falkens coopers bridgestone anything and test them out see how u like
Old 10-25-2005, 10:11 PM   #22
Mike Peters
no smoke is no fun
Old 10-25-2005, 10:27 PM   #23
HoosierDrifter
no smoke is no fun
no smoke no fun? who cares.. sh!t..i dont. do you get better scores with more smoke? if so, someone please explain to me why more smoke matters in scoreing. and dont give me that fan pleasing bs.
Old 10-26-2005, 05:57 AM   #24
driftersil80
GT3/KB2 Drift Master
driftersil80's Avatar
Send a message via AIM to driftersil80
So....you may not get better scores for smoking....but it its FUN. Tire smoke is a HUGE part of the "excitement" of drifting. When you see those giant clouds of smoke being generated, theres something that really grabs your attention and makes your heart pound. It is an important aspect of the showmanship of drifting. And really...all drifting IS is showmanship. I mean think about it....would drifting REALLY be as exciting if the cars had NO smoke coming from the tires? It would not.
driftersil80 is offline   Reply With Quote
Old 10-26-2005, 08:25 AM   #25
Piner
Piner's Avatar
yeah and then why would kumho go to all the trouble to make red smoking tires if nobody liked tire smoke
