turbo question
This is a discussion on turbo question within the TECH Discussion Forum forums, part of the TECH Discussion category; can anyone explain in simple terms what turbo trim and a/r ratios are all about? what's the difference in a ...
Old 10-22-2005, 11:09 PM   #1
JonnySlick
JonnySlick's Avatar
Location: Just Moved to Crossville, TN from Las Vegas ... wow what a change!
Send a message via Yahoo to JonnySlick
turbo question
can anyone explain in simple terms what turbo trim and a/r ratios are all about? what's the difference in a 40 trim vs 50 trim vs super 60 trim? what the difference in a .48 A/R and a .63 A/R?
thanks.
JonnySlick is offline   Reply With Quote
Old 10-27-2005, 08:20 PM   #2
dreamdrivedrift
bumpity bump, anyone?
dreamdrivedrift is offline   Reply With Quote
Old 10-27-2005, 09:24 PM   #3
TokyoDrifterxo7
Tokyo7even
TokyoDrifterxo7's Avatar
not 100% sure but as far as my knowledge trim is the actually turbo housing size and A/R ratio is the tube size in the turbo. The scroll is measured by the cross-sectional area of the scroll's "tube" (A) and the distance from the center of the "tube" to the turbine shaft (R). It basically determines how restrictive the housing will be, versus how quickly the turbine will spin up. smaller A/R ratio, quicker spool up.
