This is a discussion on cressida springs within the TECH Discussion Forum forums, part of the TECH Discussion category; What springs would be good for a 1986 Toyota Cressida? I was thinking of using toyota supra springs from the ...
cressida springs
What springs would be good for a 1986 Toyota Cressida? I was thinking of using toyota supra springs from the same year or try putting aftermarket ones for a 86 supra. If not good, could I use AE86 after market springs? I need springs that will make the car still but not put it too far to the ground.
thanks |
I have an 86 cress too. What ever you do, do not put 88-up supra springs in there! I got some misleading info and bought the kit, which was a waste of money, and it RAISED the car!!
i believe if you use ae86 aftermarket springs and shocks it will work for the front with some aw11 short stroke struts.then for the rear ae86 springs with camero struts will also work i believe
