what kind of roll cage to get?
This is a discussion on what kind of roll cage to get? within the TECH Discussion Forum forums, part of the TECH Discussion category; i am planning on getting my Gloria ready to get sideways. not that is has a problem now. but i ...
Old 11-23-2005, 11:37 PM   #1
sik_y32_gloria
sik_y32_gloria's Avatar
i am planning on getting my Gloria ready to get sideways. not that is has a problem now. but i was curious on what type of a roll cage should i get. any and all comments good or bad are welcome. thank you for your time. -robert
sik_y32_gloria is offline   Reply With Quote
Old 12-22-2005, 01:47 AM   #2
buddy
depends on what you wanna do...if its comp then figure out what you ned for the league...otherwise at cost...a roll bar over you is the cheapest thing to do...if you don't wanna buy one just grab from good bar (not sure on specs) and bend it the way you need it.
Old 12-22-2005, 02:13 AM   #3
Mike Peters
why do you need a cage to drift?
Old 01-04-2006, 12:11 PM   #4
drift4ever
drift4ever's Avatar
Send a message via MSN to drift4ever
roll cage
The roll cage is an "added protection" and a just in case... plus it makes the car even stiffer so that you can slide instead of roll, which is not good. But that's just how I see it.
drift4ever is offline   Reply With Quote
Old 01-11-2006, 02:48 PM   #5
JunpoweR
JunpoweR's Avatar
Added protection is correct
Stiffening the chassis won't make you roll less as much as installing sway bars
and stiffer suspention.
Old 01-11-2006, 02:56 PM   #6
BenR
BenR's Avatar
If you are going to get a cage I'd look up your car in the SCCA GCR for the Improved Touring, Showroom Stock, or Touring classes.
I prefer custom welded cages as they can be much more comfortable and often more safe if you have a good shop doing it.
BenR is offline   Reply With Quote
Old 01-11-2006, 03:12 PM   #7
kidynomite
Send a message via AIM to kidynomite
Get a custom one from someone who knows how to make one.
kidynomite is offline   Reply With Quote
Old 01-12-2006, 09:10 AM   #8
drift4ever
drift4ever's Avatar
Talking rur right
i was taking into consideration the installing sway bars and stiffer suspension was a given... my view is the cage is just connecting the whole care together so it would b harder to roll than if there was no cage... but again ur right, sway bars and the like will do a much better job at keeping the car planted.
Old 01-15-2006, 09:41 PM   #9
sik_y32_gloria
thanks for all your comments
