Brake controller installation?
This is a discussion on Brake controller installation? within the TECH Discussion Forum forums, part of the TECH Discussion category; Hey, I'm redoing the brake lines on my 91 S10 Blazer that will eventually be setup for drifting. I want ...
Old 12-30-2005, 10:40 AM   #1
driftnblzr
Hey,
I'm redoing the brake lines on my 91 S10 Blazer that will eventually be setup for drifting. I want to install a bias controller inside the cab while I'm at it. What is the easiest way to install the controller? Should I route the entire line through the cab or should I just drill a couple holes and place grommets around the line and run the lines up to the controller and then back down to the frame? Any help would be greatly appreciated. Thanks
driftnblzr is offline   Reply With Quote
