Clutch Sticking
This is a discussion on Clutch Sticking within the TECH Discussion Forum forums, part of the TECH Discussion category; Guys I'm having a big problem with my clutch. I can't get it into any gear. Yesterday it was having ...
Old 01-01-2006, 09:20 AM   #1
right-hand s13
Clutch Sticking
Guys I'm having a big problem with my clutch. I can't get it into any gear. Yesterday it was having problems going into 1st gear. But now I can't even get it into any gear. I have to start in second gear. The fluid is full and it doesn't make any grinding noises so I didn't think it was going out. Maybe my clutch master cylinder needs replacing or do you think my clutch is going out completly.
right-hand s13 is offline   Reply With Quote
Old 01-02-2006, 08:14 PM   #2
DRIFTER-M
-yes, yes I am sideways-
DRIFTER-M's Avatar
Send a message via AIM to DRIFTER-M
It is probably the master cylinder. When you get into the car, is the clutch sometimes on the floor? Do you have to push or pull it up?
When the master cylinder is having probs, that is usually what happens(what you are describing).
Luckly, its not that big of a fix, and doesnt cost all that much money :-D
Hope I could help.
DRIFTER-M is offline   Reply With Quote
Old 01-07-2006, 11:07 AM   #3
stolen
Send a message via AIM to stolen
agree^^. mine started doing the same (hard getting it into first) and found out my clutch master was leaking internaly so i never lost any fluids. if your gona change that you should change slave cylinder to cause thats old and easy to fix.
stolen is offline   Reply With Quote
Old 01-07-2006, 12:08 PM   #4
drift240
drift240's Avatar
Send a message via AIM to drift240 Send a message via MSN to drift240 Send a message via Yahoo to drift240
Same problem here. I never lost fluid, just constantly losing pressure. It ended up being the slave cylinder. The replacement piece is so much more compact than the original anyway. Good luck.
drift240 is offline   Reply With Quote
Old 01-21-2006, 08:04 AM   #5
s13_speed
master cylinder or fluid
s13_speed is offline   Reply With Quote
