Spray Can Bliss
This is a discussion on Spray Can Bliss within the TECH Discussion Forum forums, part of the TECH Discussion category; need some help with painting my sil80 flat black, rattle can, what kind of paint how many coats how deep ...
Old 03-28-2006, 08:39 PM   #1
GotNismo?
But officer i swear....
GotNismo?'s Avatar
Spray Can Bliss
need some help with painting my sil80 flat black, rattle can, what kind of paint how many coats how deep do i sand, any help is much appriciated
Old 03-28-2006, 09:42 PM   #2
Slapshotnerd
Slapshotnerd's Avatar
http://www.autobody101.com/articles/...=Rattle%20Cans
i went to google.com and typed in 'how to spray paint' and this came up.
Slapshotnerd is offline   Reply With Quote
Old 03-29-2006, 10:14 AM   #3
TokyoDrifterxo7
Tokyo7even
TokyoDrifterxo7's Avatar
it will tell you for best results on the back of the can. I used some krylon ultra flat black and came out with really nice results. I recommend getting a spray can handle. It helps a lot and your finger wont get tired. Also a good prep with the primer is good, stay with the gray primer it has the best results. I used 3 coats on mine, not sure on how many cans i used, was quite a few tho.
Old 03-30-2006, 11:32 AM   #4
GotNismo?
GotNismo?'s Avatar
ok so 2 coats of primer then 3 or 4 coats of ultra flat black. what kind of paint? interior exterior should do fine huh?
Old 03-31-2006, 07:44 PM   #5
defiantfc3s
Defiant Drifter
defiantfc3s's Avatar
Send a message via AIM to defiantfc3s Send a message via MSN to defiantfc3s Send a message via Yahoo to defiantfc3s
I wet sanded the factory paint on my FC with a 220 grit and then wet sanded again with 400. Then I did 2 good even coats with Dupli-Color Flat Black Primer. Not one chip after 6 months.
defiantfc3s is offline   Reply With Quote
Old 04-01-2006, 07:20 PM   #6
TokyoDrifterxo7
Tokyo7even
i used krylon ultra flat black. comes in the camo can, should be able to find it at wal*mart, however they probably wont have enough cans on hand. I stopped off at several wal*marts and just came back whenever they re-stocked the color.
