sr20 ignition issues
This is a discussion on sr20 ignition issues within the TECH Discussion Forum forums, part of the TECH Discussion category; ok the ignition stays on constantly, i cannot start the car with the key, either the ignition relays starts buzing ...
Old 04-08-2006, 10:07 AM   #1
GotNismo?
But officer i swear....
GotNismo?'s Avatar
ok the ignition stays on constantly, i cannot start the car with the key, either the ignition relays starts buzing or the acc relay on the drivers panel starts clicking, i also noticed that the relay coming off the fuse panel right underneath the clutch pedal clicks.... when i jump the starter off to start the car, i have to let 5th gear out to kil th emotor the key doesnt do anything.... i can start the car and everythign with out it. i did a auto to manual swap. but i have the wires jumped off as i should.... if any one has any clue as to how to solve this or if anyone has had this problem before any help would be much appriciated , thanks
Matt
Old 04-10-2006, 03:13 AM   #2
TokyoDrifterxo7
Tokyo7even
TokyoDrifterxo7's Avatar
double check and triple check your work. If you dont see anything wrong, have someone that has done the swap look it over. I would only be able to help you if i was there to look over what you have, sorry. But here is a helpful site that you can run through and possibly find what your mistake was. http://www.srswap.com/faq/index.asp
If you still cant figure it out, post in the Zilvia.net forums, they are always helpful. best of luck
Old 04-10-2006, 05:02 PM   #3
Stannyboy
Stannyboy's Avatar
agreed with tokyo.. if your car started fine with the ka.. then u wired something wrong.
