This is a discussion on Widebody?Pros? Cons? within the TECH Discussion Forum forums, part of the TECH Discussion category; Can someone tell be the pro's and con's of going widebody?...
Thread Tools |
Rating:
Display Modes |
mmmm...Spirit R......
Oh Baby!
i guess the pro of a widebody is that you have a wider stance for better traction and handling i guess, plus it looks cool.
cons......dont crash its just one more thing to fix if you do, and if you go widebody you will need wider tires meaning more traction meaning for drifting you may need more power depending on your style and how much you really do drift.
unless you have some fat *Censored**Censored**Censored* wheels and sick offset its lame
but pros, honda drivers will give you props cons, your car will look ricey and you will have wasted 500 or 1000 or whatever and might not even have a diff or something.//lame. |
pros - can fit wider wheels
- looks a lot better (in most circumstances) cons - costs money to install and paint - You have to cut the body underneath the widebody to fit it (if it's done properly), which means you can never go back to stock form - in most cases you're swapping out factory sheetmetal for a fiberglass or urethane widebody |
-yes, yes I am sideways-
Pros
-Looks sweet -can run wider wheels -looks sweet ![]() Cons -You have to have wide wheels that fill it out or else it just looks stupid -expensive for the wheels -remember, you will be wider. If this is a daily car too, it may be harder to park and stuff depending on how wide you go. |
Are 50mm overfenders 50mm wider on each side? Making the car 100mm overall or is 50mm the overall size of the car?
thats correct brainfood
#9 | |
no, 50 mm wider each side, so 100 mm wider overall.
#11 | |
#12 | |
cons = they fit/look like *Censored**Censored**Censored**Censored*, and is one more thing you have to re-buy when you hit |
#13 | |
But on the plus side its one more thing you can buy when you hit. Usually body work is more expensive then painting a new overfender and pop riviting it back on. At least good body work
Circle Track Guy
Widebodies are also intended for if you change around suspension pick-up points. A lot of times, racers will widen a frame or use a new k-member in order to move the control arm pick-up points out further from the centreline of the car.
This will be in concert, often, with raising the frame/k-member in the body in order to drop the overall ride height (sometimes called "channeling") and/or drop spindles, tubular a-arms of varied lengths, and many other significant suspension geometry changes. Sometimes, even, the widebody over-fenders or "fenderboxes" as the old-schoolers call 'em, housed oil coolers, radiators, intercoolers, or various ducts for venting hot engine bay air out and/or cool air for the brakes in. A good example of this would be anything from the old IMSA GTU ranks, like this S13 driven by Butch Leitzinger.
#15 |
octagon, thank you for bringing up that excellent point!! good stuff!!!
also, brainfood, good point as well, i guess that is true, ebcause its way easier to replace a 200 dollar set of overfenders than re-true a quarter panel |
#16 | |
#17 |
I started out with 50mm over fenders, but i tweeked them and trimed them to get them smaller. hold them down while you poprivet them on and you can make em as wide as you want really. And yeah i used em cuz my quarter panels were pretty well *Censored**Censored**Censored**Censored*ed anyway. Much cheaper and faster than real bodywork. Heres a few progress pics of mine.
http://dailydrifter.com/FORUMS/showthread.php?t=117 |
#18 |
Helo OCTAGON great pic those were the GLORY DAYS so many memories.The good ol IMSA GTU-GTO and prototype battles. IMO that was the greatest era in motorsports(tears)
. BRAINFOOD I got the same prob with my S13 damaged QTR but I think Im gonna fix the stock crap LMK whats up with your whip.
#19 | |
luckily I had some friends help out with some parts for free but even if I paid for them it wouldnt have been more than a couple of hundred. Then probably $70-$100 for my exhaust then I will be back on the road.tirekillers: How much wider are your overfenders now? I would run them if I only had to run 25mm bolt ons to flush my wheels so if they were maybe 20mm wider that would be cool since I can run about a 5mm spacer now to flush them. |
#20 |
I measured from the spring out on both sides while i was installing them. I got 13.5 inches to the overfender wich is about an inch wider than where the lip was. Now, my lip was pulled some before the overs so i dont really have a good baseline but that should give you atleast something to work with.
A little more detail on my setup for reference. The rear wheels are 18x10 +24 with no spacers. Tire is a 235/40. The rear was aligned to -1.5 camber with the old wheels (17x7.5 +27 ) and has not been realigned yet.
#21 | |
those are flush? I run 17x9 +20 or +15 and they are flush with 225's. So the 10's you are running should sit in about the same place. But I run those one stock fenders just the lip rolled. ahhh nevermind forgot your s13
#22 |
No, I wouldnt say they were flush with the overs, im gonna run a spacer once i switch up to a 255-265/35 tire. Without the overs these were slightly mexi-flush i prolly could have added some camber to fix it but i wouldnt have been able to go to a wider tire.
And yeah im MOSTLY S13.
#23 |
bodyworking metal sucks, body working fiberglass is torture. i work on classic vettes, i think i'm gonna stick with metal. plus plastic fender flares bring a classic jdm feel to early 90's cars IMHO
#24 |
im late, but a wide body that is wind tunnel tested will give you more downforce and allow for wider wheels and hiding more objects in the wider body(IE relocating oil coolers, radiators, etc.). For a street car its just for cool points, or hater points. For REAL race cars it is beneficial, for all these street cars, there is no point of wasting your time and money when it could be spent on better things (unless you are doing it to a show car).
#25 | |
i mean, my motor is in the "End all be all" stage and the suspension components i have chosen work exceptionally well.... so what else is their right? a bucket, a LSD, and baller wheels, i have all 3, so now, maybe widebody??? gotta fit those 18x13 works somehow |
