E-Brake Questions?
This is a discussion on E-Brake Questions? within the TECH Discussion Forum forums, part of the TECH Discussion category; At club 4ag some guy said something about adjusting the cable tension on your e brake. Is the cable tension ...
Old 02-04-2004, 07:05 PM   #1
clutch
it works!
clutch's Avatar
Arrow E-Brake Questions?
At club 4ag some guy said something about adjusting the cable tension on your e brake. Is the cable tension allowed to be adjusted so you can pull it up just a little and it will have full effect? Thanx.
clutch is offline   Reply With Quote
Old 02-04-2004, 11:24 PM   #2
_uG TM
Touge only.
Yes... the adjuster is on the lever. This can cause rear pad/lining failure if not adjusted properly. You can also ruin your rear disks, and calipers.. it can also stick and cause dragging, lower gas milage, and eventually brake failure by either having metal to metal contact on the brake, and get worse from there.
_uG TM is offline   Reply With Quote
Old 02-10-2004, 04:43 PM   #3
Chachi
Chachi's Avatar
Angry
Yes, I should know... my day went like this a few months ago after adjusting:
Me: My car feels sluggish today
Girlfriend: Whats that smell?
Me: S#!t
Chachi is offline   Reply With Quote
