This is a discussion on Engine weights. within the TECH Discussion Forum forums, part of the TECH Discussion category; Since it's useful information when deciding on swaps, etc... everyone post engine weights here....
Thread Tools |
Rating:
Display Modes |
ACDSevenGuy
Engine weights.
But in different swaps different things are required. Are we supposed to post weights with tranny? with crossmember? with turbos? racing beat aluminum rotor housings? hehe.
ACDSevenGuy
Just engine weights. It's more of a personal thing, but I thought it could be useful for others as well. Well, others that are willing to use the ::cough:: seach button ::cough::
[ Engine weight engine weights engine weigh transmission weight transmission weights ]
Without transmisison (figure +100-150lbs) A12 87 kg 192 lbs A14 93 kg 205 lbs L18 118 kg 260 lbs CA18ET 118 kg 260 lbs QR25DE 121 kg 267 lbs CA18DET 128 kg 282 lbs SR20DE 139 kg 306 lbs SR20DET 149 kg 328 lbs FJ20ET 166 kg 366 lbs (205 hp) KA24DE 167 kg 368 lbs (est) With Transmission: SR20DET 490 lbs RB25DET 667 lbs (280 hp) VG30DET 589 lbs Ford Small Block V-8 487 lbs Chevy Small Block V-8 575 lbs -MR Last edited by mranlet; 02-11-2004 at 09:29 AM. |
more then meets the eye
hopefully this might help put a end to the ka vs sr posts that seem to pop up every week
#6 | |
Moderator
My tyranny weights about 180lbs My 7M-GE alone weights 300LBS DAMN CAST IORN!
Good call - fixed it.
I hope that the words at the top work in the search engine and thanks! Don't lip the cast iron! RB's are all iron... Iron is less susceptable to warpage and dissapates heat better than : : aluminum. You can make more power safer even though there;s more weight-MR |
| Tags |
| ca18det engine weight, rb25det engine weight, sr20de engine weight, sr20det engine weight |
