Timing on an SR20DET
This is a discussion on Timing on an SR20DET within the TECH Discussion Forum forums, part of the TECH Discussion category; HEy everyone, could anyone give me a heads up on how to check the timing on an SR20DET redtop. I ...
Old 08-22-2006, 04:25 PM   #1
dshytz
HEy everyone, could anyone give me a heads up on how to check the timing on an SR20DET redtop. I think my timing on my engine is off. Can anyone help me? THANKS
dshytz is offline   Reply With Quote
Old 08-23-2006, 01:34 AM   #2
sivart33
sivart33's Avatar
get a timing light and conect a spark pluge wire from the coilpack to the spark plug(piston number one) and them time it from there, or go to a nissan dealership and have them do it for 80 dollars and hour.
sivart33 is offline   Reply With Quote
Old 08-23-2006, 11:34 AM   #3
dshytz
Thanks, but if there is something wrong with the timing, is it easy to correct it? How would i be able to do so? ANYONE?
Old 08-23-2006, 01:38 PM   #4
NM Drift Group
NM Drift Group's Avatar
set the car at top dead center TDC (1st piston up and yellow mark on crank)
Pull the valve cover
pull cam angle sensor
line up 1st dot on cam sensor shaft
slide in so that the 2nd dot rotates and lines up with the mark on the cam shaft housing
heavythrottle.com has a sr faq for pics and instructions
NM Drift Group is offline   Reply With Quote
Tags
sr20det how to check the timing, sr20det redtop how to set timing, sr20det timing
