rearend Swap questions.
This is a discussion on rearend Swap questions. within the TECH Discussion Forum forums, part of the TECH Discussion category; I have a 1985 corolla gts and I am looking to get another rearend because mine went out. Im wondering ...
Old 09-28-2006, 03:12 PM   #1
!12!
I have a 1985 corolla gts and I am looking to get another rearend because mine went out. Im wondering is there an alternative rearend from other cars that will bolt on directly on there?
thanks
!12! is offline   Reply With Quote
Old 09-29-2006, 09:12 AM   #2
Piner
Piner's Avatar
1979-81 toyota supra bigger diff stronger, and has some pretty good disc brakes
Old 09-29-2006, 08:51 PM   #3
!12!
cool so its direct bolt on? or do i have to do minor mods? and also do you know if it has an lsd?
Old 09-29-2006, 10:00 PM   #4
emission
Moderator
emission's Avatar
Here's a Toyota supra online repair manuel for that specific year.
http://www.cygnusx1.net/Supra/Library/TSRM/MK2/
LSD equiped
Old 09-30-2006, 06:07 PM   #5
Piner
Piner's Avatar
sorry emission but the MK2 has Irs that would need to be custom fitted to the corrolla and it doesnt bolt up
the MK1 has a solid axel that has all the same attacment points as a AE86 so it bolts up but finding one with an LSD is harder but you could get the center section of a MK2 with LSD and swap it into the MK1 solid axel
Old 09-30-2006, 09:52 PM   #6
!12!
Oh cool. now i gotta hunt down an MK1 rearend and a MK2 middle lsd section thanks alot guys helped me out alot. so the MK2 lsd section should directly bolt on to the MK1 right? cool thanks again
