SR20det Smoking
This is a discussion on SR20det Smoking within the TECH Discussion Forum forums, part of the TECH Discussion category; Hello, can anyone one give me any ideas on why my Sr20det redtop is Smoking(white smoke) when i start it. ...
Old 11-11-2006, 04:52 PM   #1
dshytz
Unhappy SR20det Smoking
Hello, can anyone one give me any ideas on why my Sr20det redtop is Smoking(white smoke) when i start it. It just all of a sudden, i drove it, parked it, started it 2 days later and the engine began sputtering and spitting out white smoke. so I decided to change the spark plugs and they were black as night, checked my gas pump, checked almost all the wiring...but nothing helped. What can it be? the last time i drove it, it ran fine. HEEEELLLPPPP!!!!! PLEASSEE!!!!
dshytz is offline   Reply With Quote
Old 11-11-2006, 04:52 PM   #2
Mike Peters
where do you live?
Old 11-11-2006, 08:29 PM   #3
markeese180sx
markeese180sx's Avatar
turbo going bad? headgasket gave out?
edit: any coolant in your sparkplug valley?
Old 11-12-2006, 07:31 AM   #4
zerodrifter
zerodrifter's Avatar
Send a message via AIM to zerodrifter
ummmmm valve seals.....
zerodrifter is offline   Reply With Quote
Old 11-12-2006, 01:30 PM   #5
HoosierDrifter
mine is doing the same thing... except only at idle 15% of the time. i figure my problem is a headgasket bout ready to pop.
HoosierDrifter is offline   Reply With Quote
Old 11-27-2006, 09:11 AM   #6
Chachi
Chachi's Avatar
does it go away when you drive? does it get worse when you floor it? are you running a SAFC or the like? is smoke pure WHITE or slightly blue or grey? Are the plugs shiny gooey black? carbon black? smell like fuel? more info would get you a better answer without someone actually looking at it.
my car lets out tons of greyish smoke when I let it idle for a while after running it hard, but I am not losing coolant, so I believe its my turbo seals
Chachi is offline   Reply With Quote
Old 11-27-2006, 12:12 PM   #7
dshytz
Hey fellas, thanks for replying,
Well, starting from first question down, I'm located in huntington beach,Ca.
Okay, It's spitting out white or grey smoke, tough to tell. When i changed the plugs, after my car took a dump, the plugs were black (old plugs) and a lil shiny. My car has always ran rich, so yes there is the smell of 91 octane. I don't have a AFC or SAFC. It feels like i'm losing compression. My car was running fine until the day i started it up. It does get worst of course when i try to floor it, (didn't want to screw things up any more then it was). I think all questions were answered. Just curious, if it's a head gasket, how hard, from 1 to 10, is it to fix? Valve seal? I'm an amatuer when it comes to mechanics. Any help would be great. Thanks again everyone.
Old 11-28-2006, 09:49 AM   #8
dshytz
anyone? Help ca...r... dy...ing.
Old 11-30-2006, 10:49 AM   #9
dshytz
Originally Posted by Mike Peters View Post
where do you live?
Huntingto beach, Cali
Old 11-30-2006, 02:27 PM   #10
Momentum_GT
If you haven't already try doing a compression test to possibly rule out or find out if it's your head gasket thats going out. I would also advise doing a leak down test as well to see if your valves are bad. Hope that helps any.
-Jon
Momentum_GT is offline   Reply With Quote
Old 12-01-2006, 08:58 PM   #11
dshytz
Talking
-Jon
hey ya, when ya say valves, what does that mean and what does it do? And what are turbo valves? man, this is though work.... when doing a compressin test what exactly are we looking for here? leak down? thanks everyone. great info so far....
Old 12-05-2006, 09:21 PM   #12
K's Factory
SHOP
Send a message via AIM to K's Factory Send a message via Yahoo to K's Factory
do A leak down test and also a compression test... also it could be that your piston rings are shot.does it smell like oil or coolent??
K's Factory is offline   Reply With Quote
Old 12-07-2006, 09:50 AM   #13
dshytz
Smells like gas mainly. and maybe oil? it's tough to tell. thanks.
Old 02-14-2007, 02:38 PM   #14
dshytz
Hey markeese or anyone, would you happen to know how to figure out if the turbo is going bad? Thank you
Old 02-25-2007, 10:30 AM   #15
Chachi
Chachi's Avatar
usual signs are oil in your intercooler pipes, smoking on take off, loud noise coming from turbo and low boost, shaft play in wheel
Old 02-26-2007, 06:03 PM   #16
dshytz
Unhappy
Thanks, I tried to do a cheap fix by getting a new turbo, but the car still acting the same...darn.
