Auto to Manual
This is a discussion on Auto to Manual within the TECH Discussion Forum forums, part of the TECH Discussion category; Im new to this forum, just saying hi. Ok now as my first post, i wana ask a few questions. ...
Old 02-11-2004, 11:49 PM   #1
WingsofWar
WingsofWar's Avatar
Send a message via AIM to WingsofWar Send a message via Yahoo to WingsofWar
Auto to Manual
Got my 98 kouki 240sx SE here, ABS and VLSD packed with other fun stuff. But shes got a problem...automatic. Now im getting ready to give that ol auto tranny a go and install a 5 speed manual.
Now heres what i got so far
Transmission from a S13 <--will this work?
Shifter
Release Bearing
Pressure plate
Clutch
Flywheel from a m/t
M/T Mounting plate
Flywheel Bolts (m/t bolts are longer than a/t bolts)
Clutch pedal
Brake pedal
Clutch master cylinder w/ reservoir
Clutch slave cylinder
Clutch hydraulic lines (Main line, bleeder line, rubber line to slave cylinder)
Drive shaft front & rear section
Adapter bolts & nuts for mounting cross-member to the 5 speed
Reverse light sensor
Neutral position sensor
5th gear sensor
Lower shift boot & plate
Upper Shift boot & Finisher plate.
I believe thats all i need for me to complete my swap. Now heres my question, the automatic ECU is different from the manual ECU
in what ways? mechanically suited for the task im ok, but when it comes to the electrical. im very lost. What things must i keep account for in order to do this swap electrical wise. I was told i needed the MT wiring harness..and others say i dont. help me out ....and please dont refer me to sites with tranny swap that deal with the SR . im refering to KA tranny. thanks
WingsofWar is offline   Reply With Quote
Old 02-12-2004, 09:11 AM   #2
Chas
Chas's Avatar
http://www.club240.com/forums/showth...&threadid=7581
There ya go.
