S13 Tension Rods
This is a discussion on S13 Tension Rods within the TECH Discussion Forum forums, part of the TECH Discussion category; Does anyone know what it takes to instal the JIC or Battle version Tension Rods on an S13? Will a ...
Old 02-12-2004, 10:29 AM   #1
DriftDisciple
Spiteful Tire Abuser
DriftDisciple's Avatar
S13 Tension Rods
Does anyone know what it takes to instal the JIC or Battle version Tension Rods on an S13? Will a jack, jackstands, typical wrenches and ratchets get the job done or will it get ugly? Do the factory pieces come out without geting crazy? Any advice from those who have tried this install is appreciated.
DriftDisciple is offline   Reply With Quote
Old 02-12-2004, 12:30 PM   #2
quickstyleRPS13
Junior Member
Send a message via Yahoo to quickstyleRPS13
its not to hard.
quickstyleRPS13 is offline   Reply With Quote
Old 02-12-2004, 03:05 PM   #3
Chachi
Chachi's Avatar
yeah, your good with that...I used an air gun, but thats cause I wanted to do it quick, You just need basic tools. Took me LITERALLY 1 MIN each! hand tools will require more time obviously, but shouldnt take more than 15 min each
Make sure you have them at correct lengths (compare to stock as closely as possible....and most importantly, make sure the lock nuts are TIGHT
Chachi is offline   Reply With Quote
Old 02-12-2004, 04:25 PM   #4
DriftDisciple
Thanks for the info.
I think I'll go for it. My OEM bushings are ripped to shreds- I hope this tightens up the steering feel.
Old 02-12-2004, 06:59 PM   #5
Chas
Chas's Avatar
Super easy. Just need some basic tools like Chachi said.
