Ca18det turbo to SR20det
This is a discussion on Ca18det turbo to SR20det within the TECH Discussion Forum forums, part of the TECH Discussion category; Yeah dumb question, well dumb mistake....I bought a turbo (t25)which i thought was for a sr20det(t25g) motor but i just ...
Old 02-16-2007, 12:39 PM   #1
dshytz
Angry Ca18det turbo to SR20det
Yeah dumb question, well dumb mistake....I bought a turbo (t25)which i thought was for a sr20det(t25g) motor but i just found out that there's 2 types of t25s. I just need it to test to see if my car needed a new turbo. Would it work? The ca18det turbo into a sr20det motor? I'm mad but it's my mistake. Help please?
dshytz is offline   Reply With Quote
Old 02-16-2007, 06:32 PM   #2
Bebop
Send a message via AIM to Bebop
seeing that people put SR turbos on CAs all the time I don't see why not... it probably wont work as well but it will work none the less.
Bebop is offline   Reply With Quote
Old 02-17-2007, 10:35 AM   #3
UNITEDMASTER
Hello it should bolt up ,you may or may not need to re -clock it.
Old 02-18-2007, 03:15 PM   #4
dshytz
What did you mean by re-clock it? Thanks
Old 02-20-2007, 09:33 AM   #5
dshytz
any one else?
Old 02-20-2007, 10:42 AM   #6
UNITEDMASTER
Hello to "clock it" in terms of a turbo means to rotate the compressor side ,so that the outlet faces where you need it too
