This is a discussion on Ae86 tranny help!!! within the TECH Discussion Forum forums, part of the TECH Discussion category; just out of no where my tranny just started making wineing sounds and 4Th gear will pop out.. i am ...
Ae86 tranny help!!!
just out of no where my tranny just started making wineing sounds and 4Th gear will pop out.. i am not hard on this car. whats wrong.. could this be my clutch?? it's new
the car it the gts model i built the motor up a little |
Sounds like you damaged the synchro and most likely the gear as well. Time for a trans rebuild
How much more power are you producing over stock, how built is your engine. These trannies can start acting funny when adding power, especially when you start getting over the 150 hp range if it has alot of miles on it. If you are making signifigantly more power than stock you may want to upgrade to the mkIII supra trans, seen it done on club4ag a few times with excellent results. |
#3 | |
