ae86 engines
This is a discussion on ae86 engines within the TECH Discussion Forum forums, part of the TECH Discussion category; I am trying to figure out which engine i sould put in my 86.....I like the 4ac but it doesn't ...
Old 08-15-2007, 07:16 PM   #1
AE8622R
ae86 engines
I am trying to figure out which engine i sould put in my 86.....I like the 4ac but it doesn't have enough power.....I like the carb... most of the 86 are doing gts swap and even 20v swaps.....I want to be different...I am thinkin about puttin a 22r in my corolla..... I got a 81 celica free and it has a 22r in it...It is only a sohc but comes stock with 130 hp.......It can push over 250 hp and can even handle turbo......I am going to be runnin the 40 dce daulside drafts on it.........Do u think it can be done.....
AE8622R is offline   Reply With Quote
Old 08-21-2007, 11:14 AM   #2
AE88
hey, keep us update. i would like to see an 22r in 86. gl
AE88 is offline   Reply With Quote
Old 09-13-2007, 04:53 PM   #3
mudduck3006
king of the ricers!
mudduck3006's Avatar
Send a message via AIM to mudduck3006 Send a message via Yahoo to mudduck3006
http://www.toysport.com/catalog/Catalogue%20Main.htm
this company makes me wish i was rich. you can build a fujiwara special with this parts setup
mudduck3006 is offline   Reply With Quote
Old 09-17-2007, 02:43 PM   #4
eomund240
Don't know if your still here or not being as you haven't made a post in a month, but you have some options. I understand not wanting to do a GTS swap. It's fun to do something interesting and different. I use to have an SR5 so I kinda know what your talking about. My recommendation, don't swap to a 22R. The engine weighs about 200lb's heavier with not much Horsepower gain. I was actually looking at this very swap untill the numbers talked me out of it.
If you're really interested with staying with a carbed engine there are some options you can take with the 4-AC. For not too much (about $300) you can bolt on a down draft weber, or even spend a little more and get a side draft slider carb. I've seen a couple cars with this setup. Not only does it look awsome, but the power upgrade is decent. Getting an exhaust can help too. I've seen some turbo setups, but sadly, with the stock head, you can't do too much in the pressure dept 'cause of lack of flow. If you have any more specific questions check out www.club4ac.com
A group of us that didn't want to swap to the 4AG started this site up. We have some good info in the tech sections.
