This is a discussion on 240SX 5-SPEED Swap (DVD) within the TECH Discussion Forum forums, part of the TECH Discussion category; 240SX 5-SPEED Swap (DVD) http://store.driftingshop.com/245spswd.html 240SX 5 Speed Swap Guide Covers all the basics and even goes further, with the ...
http://store.driftingshop.com/245spswd.html 240SX 5 Speed Swap Guide Covers all the basics and even goes further, with the 5 speed brake booster install, plus more! Covers the s13 & s14 chassis - as well as pulling the motor/tranny as one and then just pulling the tranny from under the car. So you will see it done both ways. Completely explain the wiring on the s13 & s14 as well as a how to on soldering wire. This video covers it all including motor/tranny maintenance bolt/nut sizes and part #s upgrades - oil seals gaskets new parts tricks and tips etc It also shows what is compatible between the s13-s14 and auto-5 speed. It goes in-depth to show how and why the parts work and will not work. This DVD is 2-1/2+HOURS LONG. Using the newest DVD technology - Double Layer DVDs 8.5gb. 5 Speed Swap DVD Chapter Layout CH 1 - Start CH 2 Getting everything ready to pull the motor CH 3 Draining & removing the radiator CH 4 Removing the exhaust manifold CH 5 Draining & removing power steering CH 6 Removing throttle & cruise control cables CH 7 Disconnecting wiring harness CH 8 Auto tranny removal in & out of car CH 9 Auto tranny shifter linkage removal under car CH 10 Auto tranny shifter linkage removal out of car CH 11 Auto tranny speed sensor & O2 sensor removal CH 12 Removing the driveshaft under the car CH 13 Removing the driveshaft out of the car CH 14 Removing the interior stuff CH 15 Auto tranny coolant lines removal under car CH 16 Auto tranny coolant lines removal out of car CH 17 - Auto tranny mount & cross member removal under car CH 18 Auto tranny mount & cross member removal out of car CH 19 Auto tranny gusset removal under car CH 20 Auto tranny crank angle sensor removal out of car CH 21 Auto tranny bell housing bolts removal under car CH 22 Auto trany bell housing bolts removal out of the car CH 23 Auto tranny removal out of the car CH 24 Auto tranny removal under the car CH 25 Auto tranny flywheel & torque converter removal CH 26 A/C compressor removal CH 27 Bolting up the engine lift in the correct spots CH 28 Pull motor/tranny clip CH 29 Motor maintenance CH 30 Clutch & flywheel install CH 31- Pedals and brake booster install and removal CH 32 s13 clutch pedal in a s14 and vise versa CH 33 Auto brake booster removal CH 34 Front seat removal CH 35 Under Dash CH 36 Auto brake pedal removal CH 37 Auto brake booster removal CH 38 Auto brake pedal pin removal CH 39 Auto brake pedal removal cont. CH 40 Clutch master cylinder install CH 41 Brake & clutch pedal installs out of the car CH 42 5 speed brake booster install CH 43 Pedal installs under dash CH 44 Clutch master cylinder CH 45 Clutch slave cylinder CH 46 5 speed swap wiring CH 47 Under dash wiring CH 48 Under dash wiring out of car CH 49 Wiring the pedals I the car CH 50 Engine bay wiring behind fuse box CH 51 Removing the ECU CH 52 ECU wiring CH 53 5th & neutral pos. switches wiring CH 54 ECU talk CH 55 5th & neutral pos. switches out of car CH 56 Installing ECU CH 57 s13 5 speed swap wiring convertibles too CH 58 5 speed transmission overview CH 59 5 speed tranny shift linkage woes CH 60 Prepping the tranny CH 61 Throw out bearing CH 62 Tranny prepping cont. CH 63 5 speed & auto speed sensor differences CH 64 Installing motor/tranny back into car CH 65 Installing motor/tranny into car clip CH 66 s13 & s14 tranny cross member differences CH 67 s14 AT & MT driveshaft differences CH 68 s13 & s14 5 speed driveshaft differences CH 69 Installing driveshaft & tranny cross member CH 70 Installing radiator fan & shroud CH 71 Installing tranny in & out of car CH 72 Installing tranny from under the car CH 73 Bell housing bolt sizes & part #s CH 74 s13 & s14 AT & MT gusset differences CH 75 Starter motor & crank angle sensor install CH 76 Installing short shifter & tranny fliud CH 77 - Tranny fluid CH 78 Install everything left off CH 79 Power steering fluid refilling procedure http://store.driftingshop.com/245spswd.html __________________
DRIFTING.com @ FACEBOOK DRIFTING.com @ FACEBOOK DRIFTING.com @ TWITTER DRIFTING.com TWITTER DRIFTING.com STORE DRIFTING.com Tel.(877) 786-7694 The BEST WAY to reach DRIFTING.com is by calling between 11AM-5PM (PACIFIC STANDARD TIME) If you are on the EAST COAST then call at 2PM. If you reach our voicemail then CALL BACK AGAIN between 11AM-5PM (PACIFIC STANDARD TIME) |
