This is a discussion on BEE*R REV Limiter/KA24DE within the TECH Discussion Forum forums, part of the TECH Discussion category; Anyone know the exact pins for the a BEE*R Rev limiter to work on a KA24DE ??...
Thread Tools |
Rating:
Display Modes |
Not to bring up a dead thread, but since it was unanswered and my friend and I just figured this out, I thought I would post.
To use the Bee*R rev limiter on a KA24de, we connected the power and ground to the obvious sources on the ecu. The white wire connects to the ebrake switch. The green and yellow wire were a little confusing/frustrating since there were only 2 and we couldn't figure out the right combination. Green wire of the unit - slot 1 ignition signal (white) on ecu Yellow wire of the unit - slot 40 camshaft position sensor (white) on ecu Hope this helps! |
i hooked mine up to the ignition signal and the tach. i never hooked up the handbrake on and make sure to cut the wire that is need for your car. gray for 4 and brown for thoses rotarys. heres the link i used
http://www.driftworks.com/resources/...itting,16.html just need to get a pinout for a ka and your set
