DIY Four Wheel Alignments
This is a discussion on DIY Four Wheel Alignments within the TECH Discussion Forum forums, part of the TECH Discussion category; Was curious to know if any here do their own wheel alignments? What techniques do you use? Is caster/kpi, thrust ...
Old 10-07-2007, 10:49 AM   #1
thetech
Is caster/kpi, thrust angle, bump steer etc......... calculations ---------- included in your solutions?
www.thatsanewconcept.com
Old 10-15-2007, 09:18 PM   #2
mranlet
mranlet's Avatar
I use the Hunter alignment rack where I work, but used to use string and a plumb bob in my driveway before that happened.
- Use a level surface
- Measure camber with a protractor against the wheel hub in comparison to a plumb line
- Measure caster with the steering wheel straight and a magnetic angle finder along the strut, or by measuring from ball joint to a known point along the longitudinal axis of the car (stamped hole in frame rail, etc)
- Measure toe with a broomstick or taut string placed along the level, center face of the tire. Measure from a given point on the body (doorseam, molding line, etc) to the string in multiple points and use some "SOHCAHTOA" to determing the angle
Finito!
