RB25DET 240SX SWAP DVD (By DRIFTING.com/SkyoPerformance/SR20Store.com)
This is a discussion on RB25DET 240SX SWAP DVD (By DRIFTING.com/SkyoPerformance/SR20Store.com) within the TECH Discussion Forum forums, part of the TECH Discussion category; RB25DET Swap RB25DET Swap RB25DET Swap RB25DET Swap RB25DET Swap RB25DET Swap RB25DET Swap RB25DET Swap RB25DET Swap RB25DET SWAP ...
Old 12-14-2007, 04:39 PM   #1
INFO
INFO's Avatar
RB25DET Swap
RB25DET Swap
RB25DET Swap
RB25DET Swap
RB25DET Swap
RB25DET Swap
RB25DET Swap
RB25DET Swap
RB25DET Swap
RB25DET SWAP / INSTALL - 240SX DVD
Chapter Outline
1
Remove lower engine bay components
-TC Rods
-Sway Bar
-Brackets
-Lower Control Arms
-Rack & Pinion
-Tie Rods
-Cross Member
2
Clutch & Flywheel
-RB Flywheel
-SPEC Clutch
-Pilot Bushing
-Clutch Alignment Tool
-Pressure Plate
-Torque to Spec
3
Motor Prep
-Lower Harness
-Motor Mounts
-RB vs. SR Harness
4
Transmission/Downpipe
-Throttle Bearing
-Input Shaft
-Bolt to Motor
-Starter
-Downpipe Heat Shield
-Gasket
-O2 Sensor
-12 POINT Bolts
5
Motor/Trans Install
-Line Up Crossmember
-WOOD Block by Firewall
-Trans. Relocation Brackets
-Tap threads
-Clutch Fork Boot
6
INSTALL lower engine bay components
-TC Rods
-Sway Bar
-Brackets
-Lower Control Arms
-Rack & Pinion
-Tie Rods
-Trans/Motor Bracket
7
Ground Wire, Neutral Switch
Lower Harness
Upper Harness
Idle Control Valve
Coolant Temperature Sensor
2nd Sensor
2 Ground Wires
Cam Angle Sensor
Computer, Connect
8
Q45 Throttle Body
Throttle Cable Bracket
Vacuum Booster Hose
Fuel Filter
-Return Line
-Feed Line
9
INTERCOOLER
-Remove Bumper Support
-FABRICATE Intercooler Mounts
-Pipe/Hoses
-Cut Bumper Support
10
-Driveshaft
-Exhaust
11
Vacuum Lines
-PCV Valve
-Fuel Pressure Regulator
Power Steering
Pressure Line
Return Line
Connect to Pump
Reservoir
Power Steering Cooler
12
Radiator (S14)
-Cut Fan Shroud
-Remove Plates
-Zip Tie Fan
-Remove Foam Lining
-RELOCATE a SPACER!
-Wire the Fan, Part #1
-Radiator Brackets
-Wire the Fan, Part #2
-Bleed System
13
-Ground Wire, Block
-Slave Cylinder Install
-Slave Cylinder System Bleed
-Heater Hose Plugs
14
-Idle Control Valve Hose
-Battery Terminal Attachment
-Braille Auto Battery
-Intercooler Piping Reinstall
-Wastegate Actuator Hose
-APEX'i Intake
-MAF Sensor
15
-Fuse Box Bracket
-Throttle Cable S14
-Cable to Throttle Body
16
-Fuel Pump
-Valve Covers
17
APEX'i Power FC Intro with Steve from SR MOTOR CARS
Parts List/Source
R33 Skyline Front Clip - (Sr20Store.Com)
Syko Performance Rb25 Converted Upper And Lower Harness - (Sykoperformance.Com)
Syko Performance Motor Conversion Mounts - (Sykoperformance.Com)
Syko Performance Transmission Brackets - (Sykoperformance.Com)
Syko Performance Sway Bar Brackets - (Sykoperformance.Com)
Syko Performance 1 Piece Driveshaft - (Sykoperformance.Com)
Intercooler Piping - (Sykoperformance.Com)
Intercooler Core - (Meganracing.Com)
Couplers And Clamps - (Hosetechniques.Com)
Power Steering Cooler - (Sr20store.Com)
S13 91+ DOHC Power Steering Lines And Fittings - (Milano Motorsports)
Greddy RB25 Intake Manifold (Purchased From (Phase2Motortrend.Com)
Rb25 Intake Manifold Gasket - (Phase2Motortrend.Com)
Infiniti Q45 Throttle Body - (Junk Yard)
Infiniti Q45 Throttle Body Gasket - (Purchased From Infiniti Dealer)
Apex-I Power Intake - (Apexi.Com)
Apex-I Power FC & Commander - (Apexi.Com)
Apex-I Auto Timer - (Apexi.Com)
Flex-A-Lite Low Profile Dual Radiator Fans (#220) - (Flex-A-Lite.Com)
Clutch Stage 3 Upgrade - (Specclutch.Com)
Flywheel - Stock Resurfaced RB25 Flywheel - (Taken To Local Shop)
Steel Braided Slave Cylinder Line - (Sr20store.Com)
Braille Auto Compact Lightweight Battery - (Brailleautodevelopment.Com)
STOCK S14 Radiator (Milano Motorsports)
High Pressure Fuel Injection Hose (Local Autoparts Store)
Z32 Fuel Filter - (Purchase From Any General Auto Parts Store)
Walbro Fuel Pump - (Phase2Motortrend.Com)
S14 Throttle Cable - (Rhddesign.Com)
Fuse Box Bracket - (Custom)
5 Quarts Of Torco Full Synthetic 5W-40 Racing Oil - (Torcoracingoils.Com)
3 Quarts Of Torco Gear Oil - (Torcoracingoils.Com)
Radiator Fluid - (Local Autoparts Store)
Power Steering Fluid - (Local Autoparts Store)
DRIFTING.com @ FACEBOOK
DRIFTING.com @ TWITTER
DRIFTING.com TWITTER
