SR20DET Engine Build
Stock Forged Steel Crank
micropolished, balanced, and cleaned
WPC Treated 87mm CP Pistons
and Pins
Eagle Forged Connecting Rod
w/ ARP 2000 Bolts
NPR Stainless rings WPC
Treated
ACL Race Main, Rod, and
Thrust Bearings
ARP Head and Main studs
Cometic .040 MLS Head
Gasket
Stock Head 3 angle valve
Job
JUN 272 11.5mm Camshafts
GReddy Adjustable Cam
Sprockets
Peak Performance Valve
Springs and Titanium Retainers
Peak Performance Bronze
Valve Guides
Peak Performance Rocker Arm
Stoppers
OEM Nissan SR20DET Gasket
Set
OEM Nissan Front Cover and
Oil Pump
OEM Nissan Timing Chain
OEM Nissan Revised Timing
Chain Guides
OEM Nissan Water Pump
Greddy Aluminum Oil Pan
