RB25DET MOTOR BUILD (Update)
This is a discussion on RB25DET MOTOR BUILD (Update) within the TECH Discussion Forum forums, part of the TECH Discussion category; What up everyone, In about 3 weeks my life is going to be completely consumed again with another video in ...
Old 12-23-2007, 12:26 PM   #1
ALI's DRIFT GARAGE
What up everyone,
In about 3 weeks my life is going to be completely consumed again with another video in our RB 240 build series. I put a list together, more for myself than anything, but figured for those of you who are staying up with the project it would be interesting to know what's coming up.
I'll be posting up continuous updates of the progress of the motor, we're shooting for a solid and reliable 500hp motor and hitting up the pro-am series in '08.
The build DVD will likely be split into a few different DVDs allowing us to focus heavily on each sectioned covered. Stay up with us.
Head
- Speed O Motive
o Head port/polish
- TOMEI
o Poncam Camshafts
o Adjustable Duralumin Cam Gears
o Strengthened Timing Belt
o Head Gasket
- Deatschwerks
o 650 Injectors
- FERREA Racing Componrents
o Valves
o Retainers
o Springs
- Phase 2 Motortrend
o Seals
o Nismo Thermostat
- HKS
o Exhaust Manifold
- Greddy
o Intake Manifold
- Gizzmo
o Phelonic Intake Gasket
- KKR
o KKR560 Turbo
- NGK
o Spark Plugs
Block
- Speed O Motive
o Hone and Polish
- JE PISTONS
o Forged Pistons
o Forged Pins
o Rings
- K1 Rods
o Forged Connecting Rods
- TOMEI
o Connecting Rod Bearings
- ACL Performance
o Main Bearings
- Lopez Crankshafts
o Crank work
o N1 Water Pump
o Misc Seals and Gaskets
Other Upgrades Covered
- Driveshaft Shop
o 450HP+ Axles
- TORCO Racing Fluids
o Oil
o Assembly Lube
o Engine Break In Fluid
o Gear Oil
- SPEC Clutch
o Twin Plate Clutch
o Aluminum Flywheel
ALI's DRIFT GARAGE is offline   Reply With Quote
Old 12-23-2007, 02:13 PM   #2
INFO
INFO's Avatar
This is what the Ali's motor looked like after DVD #1
DRIFTING.com @ FACEBOOK
DRIFTING.com @ TWITTER
DRIFTING.com TWITTER
Tags
rb25det engine build, rb25det engine rebuild, rb25det motor build
