Drift Car Setup For Domestics?
This is a discussion on Drift Car Setup For Domestics? within the TECH Discussion Forum forums, part of the TECH Discussion category; WELL I WAS WONDERING WHY MOST PEOPLE USE INDEPENDANT REAR SETUPS ON DRIFT CARS IS IT TO UTILIZE THE TOE ...
Old 03-17-2008, 08:30 PM   #1
forcefedturbine
WELL I WAS WONDERING WHY MOST PEOPLE USE INDEPENDANT REAR SETUPS ON DRIFT CARS IS IT TO UTILIZE THE TOE ADVANTAGE AND MAKE A SMALLER CONTACT PATCH BECAUSE IT WOULD BE EASIER TO BREAK THE REAR LOOSE AND NOT NEED AS MUCH POWER.... BECAUSE I HAVE A 97 GT AND I HAVE BEEN THINKING OF WELDING THE DIFF AND MAKING IT A DRIFT ONLY CAR OR SHOULD I GET A DETROIT DIFF AND SLIDE THAT WAY? OR SHOULD I JUST SELL IT LIKE I WAS GOING TO DO ANYWAY AND GO WITH A 240 I WOULD LIKE TO SHOW PEOPLE THAT U CAN DRIFT STRAIT AXLE CARS AS WELL BUT I ALSO RUN INTO SHITTY EBRAKE PROBLEMS AND I WILL HAVE TO RETRO FIT A HYDRO SETUP FOR THE REAR AND STIFFEN THE SUSPENSION UP. I CAN GET THE MUSTANG UNDER 3000LBS TO HELP IT BE ALITTLE MORE FLICKABLE I KNOW THERE ARE PEOPLE DOING DOMESTICS IN DRIFTING ALREADY AND I NEED SOME HELP ON MAKING UP MY MIND HOPE U GUYS CAN HELP.... SORRY IM BORED AND I FELT LIKE WRITING A BOOK
forcefedturbine is offline   Reply With Quote
Old 03-17-2008, 08:44 PM   #2
Piner
Piner's Avatar
A book wouldnt be in all caps, please don't engage the caps lock ever again.
we slide IRS cars because most of the easy cars to build are already IRS not because solid axle is horrible or anything.
the AE86 is solid rear axle and those drift great.
building a mild drift car isnt all that hard
you will need some sort of LSD or welded diff like you said that kinda depends on your budget. Welded if you dont have much cash, an LSD is better but more money so if you have cash to spare get and LSD.
then after that its suspension suspension suspension. You don't need to buy "DRIFT" suspension thats just marketing really. Most of the time anything road racing related can be applied to drifting.
What your looking for is to remove the stock "slop" out of the suspension so this means the bushings, mounts and other stuff that can move around while your sliding and can make the car less predictable. Thats pretty much the goal of all drift cars is Predictablity and consistency. The car doesn't drift the driver makes the car drift and being able to accurately interpret what the car is doing and telling you is the main goal.
You probably have more than enough power as is right now. You need to focus on making the car more responsive suspension wise and making the interior more comfortable and confidence inspiring (racing seat to hold you in place, a easier to flick steering wheel etc)
http://e36driftbag.blogspot.com/
1999 Toyota Chaser Turbo (Germany)
1998 BMW 328is S52 swap (USA car)
199? Nissan Cefiro Turbo (Japan car)
Hold my Dragon!
Old 03-18-2008, 11:05 AM   #3
JonnySlick
JonnySlick's Avatar
Location: Just Moved to Crossville, TN from Las Vegas ... wow what a change!
Send a message via Yahoo to JonnySlick
failure to lunch (only b/c it's 12:03)
LOTS of people drift Mustangs and other domestics these-a-days ... yeah i know i know ... it sounds crazy. like some fairy hairy acid trip.
come on get real, is the GT your only car? if so, then DON'T weld the diff. you'll need something more forgiving if you have to rely on your car to drive. i hope (and assume) that you are having another car since you are wanting to make the GT a "drift only" car. if the GT is you're only car and you want to weld the diff ... then yeah you = the fail primary!
but yeah, don't use caps ever again in your life - you fail secondary at the keyboard.
fail.
Support your local drifter!
www.DriftCentral.com
JonnySlick is offline   Reply With Quote
Old 03-19-2008, 11:26 AM   #4
forcefedturbine
sorry for the caps i just use them alot , the gt is going to be drift only i have another car. I was wondering if you guys have seen anybody with a hydro ebrake setup on these cars im mainly looking for pictures of how there doing it even if its not on a gt thanks for the help!
Old 03-19-2008, 05:42 PM   #5
Piner
Piner's Avatar
hydro ebrake isnt as hard as it would seem there is a write up on this site
http://www.drifting.com/forums/showt...draulic+ebrake
hope that helps some
Hold my Dragon!
Old 03-19-2008, 06:47 PM   #6
forcefedturbine
thanks for the link is that how alot of people have been doing it. Also i have been looking at springs, all i see is lowering springs im not sure how aggressive the spring rate has to be or how low i should take the car. ive noticed most drift cars ar slammed i would like to get the mustang as low as i can without cutting the springs. im used to honda suspension setups and other imports slamming them is easy but the gt is going to be a bit of a challenge because most imports can just take a cheap pair of coil over slip on ebay specials.
Old 03-20-2008, 05:28 AM   #7
soultron
soultron's Avatar
Here's some stuff for you.
Fox Body drifting thread
Yes, it's not the same, but it's similar.
http://www.drifting.com/forums/pictures-and-video-clips/23224-fox-body-mustang-drifting.html
Then there's the Dvanz car.
Oh yes.
http://dvanz.com
Rock out with your chicken out.
1987 T/A-305 TPI/T5/3.42 SLP rear/Flowtech headers/Flowmaster 3inch exhaust/
Tokico Illuminas/Alston sfcs/TDS wonderbar/Edelbrock panhard bar/ Poly bushings
The Domestic Drifting Forum
Originally Posted by cfrost View Post
haaaaaaahahahaha soultron always wins
Old 03-20-2008, 08:55 AM   #8
cfrost
cfrost's Avatar
www.drift50.com
http://www.modiride.com
http://www.shift-lock.net
http://www.driftheroes.com
learn the basics of drifting!
Old 04-08-2008, 12:09 PM   #9
Drifting Pwns
So what's the gain in getting a hydro ebrake? On one of the links that you posted it talks about how to put them in but doesn't every mention what it benefits compared to a normal e-brake.
Old 04-08-2008, 02:23 PM   #10
Piner
Piner's Avatar
Normal eBrakes take lots of effort to operate, and some dont have the capability to lock bigger wheels and tires with large amounts of grip. Also some cars ebrakes (Like mine) use a separate drum in the disc that wears out really fast if used alot and requires constant adjustment
A hydro ebrake offers instant and EQUAL lock up of both rear wheels with very little effort. No adjustment necessary, also you can put it where ever it is comfortable for you.
Hold my Dragon!
Old 04-08-2008, 07:02 PM   #11
Drifting Pwns
K, thanks for the info. A slight change of subject, where do most drivers prefer their e-brake to be? Driver's side of the panel or passenger's?
