T.suell Ae13
This is a discussion on T.suell Ae13 within the TECH Discussion Forum forums, part of the TECH Discussion category; Wow! You're corolla is the secks, dood! So hot! (Makes me miss mine, like, alot) You gonna bring it out ...
Old 06-24-2008, 12:51 AM   #26
SageCraft
Send a message via AIM to SageCraft
Wow!
You gonna bring it out to All Star Bash this weekend? Heading out there Saturday with the Driftlive guys. Love to see you thrash out there.
I'd love a ride-a-long too
Good luck, and see you at Vegal Formula D!
~Jonny Mac
SageCraft is offline   Reply With Quote
Old 06-24-2008, 09:25 AM   #27
RAM GARAGE
yeah i would love to take it out to asb but i still need to dail in the sus. and i rather do that alone lol main focus right now is RD4 must dail it in for that
RAM GARAGE is offline   Reply With Quote
Old 06-24-2008, 11:05 AM   #28
Slapshotnerd
Slapshotnerd's Avatar
Tommy Suell for president!
Slapshotnerd is offline   Reply With Quote
Old 06-24-2008, 12:24 PM   #29
Soldat
Originally Posted by atlantian View Post
I know, you listen to the engine's pitch, but the thing is, with a highlighted section, it's just easier to just "glance" at. The thing is, using a warning light is not that convenient at all. In fact, it would seem more annoying then a traditional colored tachometer.
A warning light will catch your attention if you're not looking directly at it. A colored section will not. And since you actually spend very little time redlining the car while drifting, hitting the shift points isn't particularly crucial. You keep the motor speed and the gearbox where you need it for that particular turn and (at least for me) that's usually only at about 3-4k rpm even though my rev limiter is set to 6k.
All you really need to worry about is overrevving the motor and hurting it.
Soldat is offline   Reply With Quote
Old 06-30-2008, 04:39 PM   #30
eomund240
+1. Most engines torque band is not at the top of the RPM's. If you take a look at most Dyno sheets, you'll see that after some where between 50% and 70% the torque starts to drop off. One reason why larger engines have a major advantage. Smaller engines need to be higher in the torque band. With less power, if they drop they can't make it back up. One reason why the 4A engines have a bit more mechanical problems than larger engines.
Nice looking car mate. That blue looks pretty sweet on it. I didn't see, but I'm curious what tranny your running on that thing? If it's the Nissan 5 speed, I'm curious how well the mounts lined up.
Also what rear end are you running?
Old 07-02-2008, 12:59 AM   #31
RAM GARAGE
5sp sr tranny mounted up pretty easy welded plates to the mount and new holes not hard at all. rear end is celica supra 7.5in
almost done
