Old 11-01-2008, 01:07 PM   #1
INFO
INFO's Avatar
SR20DET PARTS List
SR20DET Engine:
SR20DET Bare engine assembly Jan 1991 - Jan 1994 10102-50F50
SR20DET Bare engine assembly Jan 1994 - Aug 1996 10102-50F52
SR20DET Bare engine assembly Aug 1991 - Dec 1998 10102-50FM2
SR20DET Short block engine assembly Jan 1991 - Dec 1998 10103-50FM0
SR20DET Cylinder Block and Oil Pan:
SR20DET Oil jet assembly Jan 1991 - Aug 1993 11560-79E00
SR20DET Timing chain oil jet Jan 1991 - Dec 1998 13081-53J00
SR20DET Timing chain oil jet Aug 1993 - Dec 1998 11560-1E000
SR20DET Rear oil seal Jan 1991 - Dec 1998 12279-18V00, 12279-30P00, 12279-1E000, 12279-53J10, 12279-85Y00, 12279-1N510
SR20DET Oil pan lower baffle Jan 1991 - Jan 1994 11113-52F00
SR20DET Oil pan lower baffle Jan 1994 - Dec 1998 11113-65F00
SR20DET Main bearing cap bolts Jan 1991 - Dec 1998 12293-53J00
SR20DET Dipstick Jan 1991 - Dec 1998 11140-52F00
SR20DET Dipstick tube Jan 1991 - Dec 1998 11150-52F00
SR20DET Crankcase plate baffle Jan 1991 - Dec 1998 11038-53J00
SR20DET Rear oil seal retainer Jan 1991 - Dec 1998 12297-53J00
SR20DET Oil pan Jan 1991 - Dec 1998 11110-52F10
SR20DET Upper oil pan Jan 1991 - Dec 1998 11110-52F01
SR20DET Upper oil pan baffle Jan 1991 - Dec 1998 11113-53J02
SR20DET Rear engine plate Jan 1991 - Dec 1998 30411-52F00 Plate between engine and tranny
SR20DET Rear plate cover Jan 1991 - Dec 1998 30417-52F00 Plate on back of upper oil pan
SR20DET Valve Cover/Cylinder Head:
SR20DET Spark plug cover Jan 1991 - Dec 1998 13287-50F01
SR20DET Spark plug cover bolt Jan 1991 - Dec 1998 01131-40F01
SR20DET Valve cover nut Jan 1991 - Nov 1992 01217-00181
SR20DET Valve cover nut Nov 1992 - Jan 1994 01217-00221
SR20DET Valve cover nut Jan 1994 - Dec 1998 08918-20610
SR20DET Valve cover washer Jan 1991 - Dec 1998 13268-97E00
SR20DET Valve cover stud Jan 1991 - Dec 1998 13508-53J00
SR20DET Valve cover red Jan 1991 - Jan 1994 13264-50F02
SR20DET Valve cover black Jan 1994 - Dec 1998 13264-50F03
SR20DET Valve cover gasket Jan 1991 - Dec 1998 13270-52F00
SR20DET Valve cover spark gasket Jan 1991 - Dec 1998 13271-52F00
SR20DET Headgasket Jan 1991 - Dec 1998 11044-50F01
SR20DET Oil cap assembly Jan 1991 - Dec 1998 15255-40F01, 15255-1P101
SR20DET Cylinder head assembly Jan 1991 - Dec 1998 11040-52F00
SR20DET PCV Valve Jan 1991 - Dec 1998 11810-79E01
SR20DET Intake valve seat Jan 1991 - Aug 1996 11098-53J60
SR20DET Intake valve seat Aug 1996 - Dec 1998 11098-1E765
SR20DET Exhaust valve seat Jan 1991 - Aug 1996 11099-53J60
SR20DET Exhaust valve seat Aug 1996 - Dec 1998 11099-53J65
SR20DET Timing chain Jan 1991 - Dec 1998 13028-53J03
SR20DET Chain guide slack side Jan 1991 - Sep 1996 13091-53J01, 13091-2J200
SR20DET Chain guide slack side Sep 1996 - Sep 1997 13091-2J200, 13091-2J201
SR20DET Chain guide slack side Sep 1997 - Dec 1998 13091-2J201, 13091-2J202
SR20DET Chain guide tension side Jan 1991 - Oct 1997 13085-53J00, 13085-1N500
SR20DET Chain guide tension side Oct 1997 - Dec 1998 13085-1N500
SR20DET Timing chain tensioner Jan 1991 - Dec 1998 13070-2J200, 13070-2J203
SR20DET Cam sprocket (intake) Jan 1991 - Dec 1998 13024-53J01
SR20DET Cam sprocket (exhaust) Jan 1991 - Dec 1998 13095-52F00
SR20DET Camshaft (intake) Jan 1991 - Dec 1998 13020-1E000
SR20DET Camshaft (exhaust) Jan 1991 - Dec 1998 13020-50F12
SR20DET Rocker arm Jan 1991 - Dec 1998 13257-53J03
SR20DET Hydraulic lash adjuster Jan 1991 - Dec 1998 13234-53J01
SR20DET Rocker shim (T=2.800) Jan 1991 - Dec 1998 13229-53J00
SR20DET Rocker shim (T=2.825) Jan 1991 - Dec 1998 13229-53J01
SR20DET Rocker shim (T=2.850) Jan 1991 - Dec 1998 13229-53J02
SR20DET Rocker shim (T=2.875) Jan 1991 - Dec 1998 13229-53J03
SR20DET Rocker shim (T=2.900) Jan 1991 - Dec 1998 13229-53J04
SR20DET Rocker shim (T=2.925) Jan 1991 - Dec 1998 13229-53J05
SR20DET Rocker shim (T=2.950) Jan 1991 - Dec 1998 13229-53J06
SR20DET Rocker shim (T=2.975) Jan 1991 - Dec 1998 13229-53J07
SR20DET Rocker shim (T=3.000) Jan 1991 - Dec 1998 13229-53J08
SR20DET Rocker shim (T=3.025) Jan 1991 - Dec 1998 13229-53J09
SR20DET Rocker shim (T=3.050) Jan 1991 - Dec 1998 13229-53J10
SR20DET Rocker shim (T=3.075) Jan 1991 - Dec 1998 13229-53J11
SR20DET Rocker shim (T=3.100) Jan 1991 - Dec 1998 13229-53J12
SR20DET Rocker shim (T=3.125) Jan 1991 - Dec 1998 13229-53J13
SR20DET Rocker shim (T=3.150) Jan 1991 - Dec 1998 13229-53J14
SR20DET Rocker shim (T=3.175) Jan 1991 - Dec 1998 13229-53J15
SR20DET Rocker shim (T=3.200) Jan 1991 - Dec 1998 13229-53J16
SR20DET Rocker arm guide Jan 1991 - Dec 1998 13218-53J00
SR20DET Valve spring collet Jan 1991 - Dec 1998 13210-D4200
SR20DET Valve spring retainer Jan 1991 - Dec 1998 13209-53J00
SR20DET Valve spring Jan 1991 - Dec 1998 13203-53J00
SR20DET Valve spring seat Jan 1991 - Dec 1998 13205-53J00
SR20DET Intake valve oil seal Jan 1991 - Dec 1998 13207-84A00 NDK
SR20DET Intake valve oil seal Jan 1991 - Dec 1998 13207-D4201 NOK
SR20DET Intake valve Jan 1991 - Jan 1994 13201-53J00
SR20DET Intake valve Jan 1994 - Dec 1998 13201-1E700, 13201-1E710
SR20DET Exhaust valve oil seal Aug 1996 - Dec 1998 13207-53F00 NOK
SR20DET Exhaust valve oil seal Jan 1991 - Dec 1998 13207-D0111 NDK
SR20DET Exhaust valve Jan 1991 - Feb 1996 13202-53J01
SR20DET Exhaust valve Feb 1991 - Dec 1998 13202-53J02
SR20DET Front Cover:
SR20DET Oil pump assembly Jan 1991 - Dec 1998 13500-50F00
SR20DET Front main seal Jan 1991 - Jan 1994 13510-40F00, 13510-53J10 NDK
SR20DET Front main seal Jan 1994 - Aug 1996 13510-53J00 NDK
SR20DET Front main seal Aug 1996 - Dec 1998 13510-53J01 NOK
SR20DET Front main seal Jan 1991 - Aug 1996 13510-53J10, 13510-53J11 NOK
SR20DET Front main seal Aug 1996 - Dec 1998 13510-53J11 NDK
SR20DET Oil pump gear set Jan 1991 - Dec 1998 15020-50F00, 15020-79E00
SR20DET Oil pump regulator valve set Jan 1991 - Dec 1998 15132-50F00
SR20DET Engine and Tranny Mount:
SR20DET Engine mount right Jan 1991 - Apr 1991 11210-40F00
SR20DET Engine mount right Apr 1991 - Dec 1998 11210-52F00, 11210-65F11
SR20DET Engine mount left Jan 1991 - Apr 1991 11220-40F00
SR20DET Engine mount left Apr 1991 - Dec 1998 11220-52F00, 11220-65F06, 11220-85F00
SR20DET Tranny mount Jan 1991 - Dec 1998 11320-35F01
SR20DET Tranny crossmember Jan 1991 - Dec 1998 11340-35F00
SR20DET Engine - Bottom End:
SR20DET Piston ring set (standard) Jan 1991 - Dec 1998 12033-53J00, 12033-53J01
SR20DET Piston ring set (0.20 oversize) Jan 1991 - Dec 1998 12035-53J00
SR20DET Crank Sprocket Jan 1991 - Dec 1998 13021-53J00
SR20DET Crankshaft assembly Jan 1991 - Dec 1998 12200-60J10
SR20DET Piston with pin (standard-1) Jan 1991 - Jul 1993 A2010-79E60
SR20DET Piston with pin (standard-2) Jan 1991 - Jul 1993 A2010-79E61
SR20DET Piston with pin (standard-3) Jan 1991 - Jul 1993 A2010-79E62
SR20DET Piston with pin (0.20 oversize) Jan 1991 - Jul 1993 A2010-79E71
SR20DET Piston with pin (standard-1) Jul 1993 - Dec 1998 A2010-54C00, A2010-75F60
SR20DET Piston with pin (standard-2) Jul 1993 - Dec 1998 A2010-54C01, A2010-75F61
SR20DET Piston with pin (standard-3) Jul 1993 - Dec 1998 A2010-54C02, A2010-75F62
SR20DET Piston with pin (0.20 oversize) Jul 1993 - Dec 1998 A2010-54C10, A2010-75F76
SR20DET Connecting rod assembly Jan 1991 - Dec 1998 12100-79E00
SR20DET Con rod bearing (standard-0) Aug 1996 - Dec 1998 12111-1N500
SR20DET Con rod bearing (standard-1) Aug 1996 - Dec 1998 12111-1N501
SR20DET Con rod bearing (standard-2) Aug 1996 - Dec 1998 12111-1N502
SR20DET Con rod bearing (standard-0) Jan 1991 - Aug 1996 12111-60J00, 12111-1N500
SR20DET Con rod bearing (standard-1) Jan 1991 - Aug 1996 12111-60J01, 12111-1N501
SR20DET Con rod bearing (standard-2) Jan 1991 - Aug 1996 12111-60J02, 12111-1N502
SR20DET Con rod bearing (US 0.12) Aug 1996 - Dec 1998 12117-1N500
SR20DET Con rod bearing (US 0.12) Jan 1991 - Aug 1996 12117-60J00
SR20DET Con rod bearing (US 0.25) Aug 1996 - Dec 1998 12118-1N500
SR20DET Con rod bearing (US 0.25) Jan 1991 - Aug 1996 12118-60J00, 12118-1N500
SR20DET Con rod bearing (US 0.8) Aug 1996 - Dec 1998 12122-1N500
SR20DET Con rod bearing (US 0.8) Jan 1991 - Aug 1996 12122-60J00
SR20DET Crank bearing (standard-0) Jan 1991 - Dec 1998 12207-60J00
SR20DET Crank bearing (standard-1) Jan 1991 - Dec 1998 12207-60J01
SR20DET Crank bearing (standard-2) Jan 1991 - Dec 1998 12207-60J02
SR20DET Crank bearing (standard-3) Jan 1991 - Dec 1998 12207-60J03
SR20DET Crank bearing (standard-4) Jan 1991 - Dec 1998 12207-60J04
SR20DET Crank bearing (standard-5) Jan 1991 - Dec 1998 12207-60J05
SR20DET Crank bearing (standard-6) Jan 1991 - Dec 1998 12207-60J06
SR20DET Crank bearing set (US 0.25) Jan 1991 - Dec 1998 12208-60J00
SR20DET Thrust washer Jan 1991 - Dec 1998 12280-60J00
SR20DET Crankshaft pulley Jan 1991 - Dec 1998 12303-52F00
SR20DET Crankshaft pulley bolt Jan 1991 - Dec 1998 12309-29S00
SR20DET Clutch:
SR20DET Flywheel assembly Jan 1991 - Dec 1998 12310-79E11, 12310-79E12
SR20DET Flywheel bolt Jan 1991 - Dec 1998 12315-52F00
SR20DET Pilot bushing Jan 1991 - Dec 1998 32202-B9500
SR20DET Intake/Exhaust Manifold:
SR20DET Upper intake manifold Jan 1991 - Dec 1998 14001-52F00 Connects to head
SR20DET Lower intake manifold collector Jan 1991 - Dec 1998 14010-52F00 Connects to throttle body
SR20DET Throttle body gasket Jan 1991 - Mar 1993 16175-53J00
SR20DET Throttle body gasket Mar 1993 - Dec 1998 16175-79S70, 16175-79S71
SR20DET Intake manifold gasket to head Jan 1991 - Dec 1998 14035-53J10
SR20DET Intake manifold middle gasket Jan 1991 - Dec 1998 14032-52F00
SR20DET Throttle cable bracket Jan 1991 - Dec 1998 16165-52F00
SR20DET Throttle cable insulator Jan 1991 - Dec 1998 18316-52F00
SR20DET Throttle body Jan 1991 - Dec 1998 16118-52F00, 16118-52F05
SR20DET Throttle position sensor Jan 1991 - Jun 1997 22620-53J00, 22620-53J01
SR20DET Throttle position sensor Jun 1997 - Dec 1998 22620-31U01
SR20DET Throttle cable pulley Jan 1991 - Dec 1998 16134-52F00
SR20DET Idle air control valve Jan 1991 - Dec 1998 23781-50F05 Tousoku
SR20DET Idle air control valve Jan 1991 - Dec 1998 23781-50F15 Atsugi
SR20DET Idle air control valve gasket Jan 1991 - Dec 1998 23785-50F00
SR20DET Exhaust manifold gasket Jan 1991 - Dec 1998 14036-53J00
SR20DET Exhaust manifold Jan 1991 - Dec 1998 14004-50F00
SR20DET Exhaust manifold stud Jan 1991 - Aug 1996 08267-03010
SR20DET Exhaust manifold stud Aug 1996 - Jun 1997 14065-75F00
SR20DET Exhaust manifold stud Jun 1997 - Dec 1998 14064-2J200
SR20DET Exhaust manifold washer Jan 1991 - Dec 1998 14037-42L02
SR20DET Exhaust manifold nut Jan 1991 - Dec 1998 08912-8401A
SR20DET Turbocharger:
SR20DET Turbocharger Jan 1991 - Dec 1998 14411-50F00
SR20DET Manifold to turbo gasket Jan 1991 - Dec 1998 14415-17M00
SR20DET Turbo to O2 pipe gasket Jan 1991 - Dec 1998 14445-26E00
SR20DET O2 extension Jan 1991 - Dec 1998 14440-50F01
SR20DET Locking washer plate Jan 1991 - Dec 1998 14495-17F00
SR20DET Oil return tube Jan 1991 - Dec 1998 15197-50F00
SR20DET Oil return gasket Jan 1991 - Dec 1998 15196-79E00
SR20DET Lubricating System:
SR20DET Oil filter bracket assembly Jan 1991 - Dec 1998 15238-52F01
SR20DET Oil pickup tube/strainer Jan 1991 - Sep 1993 15050-52F00, 15050-52F01
SR20DET Oil pickup tube/strainer Sep 1993 - Dec 1998 15050-65F01
SR20DET Oil pickup O-ring seal Jan 1991 - Jan 1994 15059-V5001
SR20DET Oil pickup O-ring seal Jan 1994 - Dec 1998 15053-1E400
SR20DET Cooling:
SR20DET Waterpump Jan 1991 - Dec 1998 21010-52F01
SR20DET Waterpump pulley Jan 1991 - Dec 1998 21051-65F00
SR20DET Clutch fan clutch Jan 1991 - Dec 1998 21082-52F00
SR20DET Clutch fan fan Jan 1991 - Dec 1998 21060-52F00
SR20DET Upper waterneck Jan 1991 - Aug 1996 11060-52F00, 11060-52F01
SR20DET Upper waterneck Aug 1996 - Dec 1998 11060-65F00, 11060-65F01
SR20DET Lower water inlet Jan 1991 - Dec 1998 13049-52F00
SR20DET Thermostat Jan 1991 - Dec 1998 21200-53J00, 21200-53J10, 21200-0C810
SR20DET Thermostat housing Jan 1991 - Dec 1998 11061-52F05
SR20DET Engine coolant temp sensor Jan 1991 - Jan 1994 22630-V5010, 22630-51E00
SR20DET Engine coolant temp sensor Jan 1994 - Aug 1996 22630-51E00, 22630-51E02
SR20DET Engine coolant temp sensor Aug 1996 - Dec 1998 22630-43Y00, 22630-44B10
SR20DET Engine coolant temp sensor Aug 1996 - Oct 1997 22630-44B10, 22630-44B20
SR20DET Engine coolant temp sensor Oct 1997 - Dec 1998 22630-44B20
SR20DET Radiator Jan 1991 - Dec 1998 21410-52F11
SR20DET Resevoir tank Jan 1991 - Dec 1998 21721-35F01
SR20DET Upper radiator shroud Jan 1991 - Dec 1998 21476-52F00
SR20DET Lower radiator shroud Jan 1991 - Dec 1998 21477-35F00
SR20DET Fuel system:
SR20DET Fuel injector Jan 1991 - Dec 1998 16600-50F00, 16600-50F02, 16600-50F10, 16600-50F12
SR20DET Small injector O-ring Jan 1991 - Dec 1998 16618-53J00
SR20DET Large injector O-ring Jan 1991 - Dec 1998 16618-10V05
SR20DET Injector insulator Jan 1991 - Dec 1998 16635-53J00
SR20DET Injector rubber back cap Jan 1991 - Dec 1998 16619-53J00
SR20DET Fuel rail Jan 1991 - Dec 1998 17520-52F00
SR20DET Fuel pressure regulator Jan 1991 - Dec 1998 22670-52F00
SR20DET Fuel pump Jan 1991 - May 1991 17042-35F00
SR20DET Fuel pump May 1991 - Dec 1998 17042-73L02
SR20DET Intake:
SR20DET Mass air flow sensor Jan 1991 - Dec 1998 22680-52F00
SR20DET Compressor inlet tube Jan 1991 - Dec 1998 16577-50F00 bolts to turbo
SR20DET Compressor inlet tube gasket Jan 1991 - Dec 1998 14465-54C00
SR20DET Intake rubber tube Jan 1991 - Dec 1998 16578-50F01
SR20DET Ignition System:
SR20DET Coilpack Jan 1991 - Dec 1998 22448-50F01
SR20DET Coilpack harness Jan 1991 - Dec 1998 24079-50F00
SR20DET Igniter chip (PTU) Jan 1991 - Dec 1998 22020-50F00, 22020-50F01, 22020-50F10
SR20DET Knock sensor Jan 1991 - Dec 1998 22060-30P00
SR20DET Camshaft position sensor (CAS) Jan 1991 - Dec 1998 23731-50F02
SR20DET Electronics:
SR20DET Wastegate control solenoid Jan 1991 - Dec 1998 14956-50F00
SR20DET Oxygen sensor Jan 1991 - Jan 1994 22690-50F00
SR20DET Oxygen sensor Jan 1994 - Dec 1998 22690-50F02
SR20DET Oxygen sensor holding nut Jan 1991 - Jan 1994 20607-V5000
SR20DET Oxygen sensor holding nut Jan 1994 - Dec 1998 20607-P6500
SR20DET ECU Jan 1991 - Jan 1994 23710-50F00 MT
SR20DET ECU Jan 1994 - Aug 1996 23710-50F05 MT
SR20DET ECU Jan 1991 - Jan 1994 23710-50F10 AT
SR20DET ECU Jan 1994 - Aug 1996 23710-50F15 AT
SR20DET ECU Aug 1996 - May 1997 23710-60F06 MT
SR20DET ECU May 1997 - Dec 1998 23710-60F07 MT
SR20DET ECU Aug 1996 - May 1997 23710-60F16 AT
SR20DET ECU May 1997 - Dec 1998 23710-60F17 AT
SR20DET Alternator Jan 1991 - Aug 1996 23100-52F10, 23100-52F11
SR20DET Alternator Aug 1996 - Dec 1998 23100-65F17
SR20DET Starter Jan 1991 - Dec 1998 23300-52F01, 23300-80F00
SR20DET Tachometer gauge Jan 1991 - Jan 1994 24825-52F00
SR20DET Tachometer gauge Jan 1994 - Aug 1996 24825-52F20
SR20DET Temperature sensor Jan 1991 - Aug 1996 25080-89903
SR20DET Temperature sensor Aug 1996 - Dec 1998 25080-89907
SR20DET
SR20DET Power Steering:
SR20DET Power steering pump Jan 1991 - Dec 1998 49110-52F00 2WS
SR20DET Power steering pump Jan 1991 - Dec 1998 49110-52F60 4WS Hicas
SR20DET Transmission:
SR20DET Clutch slave cylinder Jan 1991 - Mar 1997 30620-18V01, 30620-69F01, 30620-69F02, 30620-69F03
SR20DET Clutch slave cylinder Mar 1997 - Dec 1998 30620-0H620
SR20DET SR20DET transmission Jan 1991 - Aug 1996 32010-50F00, 32010-50F20, 32010-50F21, 32010-50F22
SR20DET SR20DET transmission Aug 1996 - Dec 1998 32010-69F10
SR20DET SR20DET front belhousing shell Jan 1991 - Apr 1995 32101-50F00
SR20DET SR20DET front belhousing shell Apr 1995 - Dec 1998 32101-50F01
SR20DET Speed sensor assembly Jan 1991 - Aug 1996 25010-35F00 Same as US S13
SR20DET Speed sensor assembly Aug 1996 - Dec 1998 25010-71T00
SR20DET Speed sensor pinion gear Jan 1991 - Aug 1996 32743-35F20
SR20DET Speed sensor pinion gear Aug 1996 - Dec 1998 32743-71T20
SR20DET Driveline/Suspension:
SR20DET Output flange (right 5 star) Jan 1991 - Oct 1995 38220-53F00, 38220-93L00
SR20DET Output flange (right 6 bolt) Oct 1995 - Dec 1998 38220-92L00
SR20DET Output flange (left 5 star) Jan 1991 - Oct 1995 38220-53F01
SR20DET Output flange (left 6 bolt) Oct 1995 - Dec 1998 38220-52F01
SR20DET Half shaft (right 5 star) Jan 1991 - Oct 1995 39600-73L00
SR20DET Half shaft (right 6 bolt) Oct 1995 - Dec 1998 39600-35F00
SR20DET Half shaft (left 5 star) Jan 1991 - Oct 1995 39601-73L00
SR20DET Half shaft (left 6 bolt) Oct 1995 - Dec 1998 39601-35F10
SR20DET Front strut tower bar Dec 1995 - Aug 1996 E4390-50F00
SR20DET Front strut tower bar Aug 1996 - Dec 1998 E4390-60F00
SR20DET Nismo front strut tower bar Jan 1996 - Aug 1998 E4420-RN521
SR20DET Rear swaybar Jan 1991 - Dec 1998 56230-39F03
SR20DET Other Desired JDM 180SX Parts:
SR20DET Digital climate control Jan 1991 - Aug 1996 27510-52F00
SR20DET Digital climate control Aug 1996 - Dec 1998 27510-60F01
SR20DET Digital control subharness Jan 1991 - Aug 1996 24042-52F00
SR20DET Resister for climate control Jan 1991 - Jan 1994 27150-51E01
SR20DET Resister for climate control Jan 1994 - Aug 1996 27150-51E05
SR20DET Cabin temp sensor Jan 1991 - Dec 1998 27720-35F03
SR20DET Sunload sensor Jan 1991 - Dec 1998 27721-35F00
SR20DET Kouki front bumper cover Aug 1996 - Dec 1998 F2022-60F** **varies by color
SR20DET Kouki optional lip spoiler Aug 1996 - Dec 1998 K6010-60F50
SR20DET Kouki fender side piece (left) Aug 1996 - Dec 1998 62025-60F**
SR20DET Kouki fender side piece (right) Aug 1996 - Dec 1998 62024-60F**
SR20DET Chuki side skirt (left) Dec 1995 - Aug 1996 76851-51F81, 76851-51F25
SR20DET Chuki side skirt (right) Dec 1995 - Aug 1996 76850-51F81, 76850-51F25
SR20DET Side skirt #2 (kit) Jan 1991 - Aug 1996 G6850-40F**
SR20DET Side skirt #2 (left) Jan 1991 - Aug 1996 G6852-40F10
SR20DET Side skirt #2 (right) Jan 1991 - Aug 1996 G6851-40F10
SR20DET Kouki side skirt kit #2 Aug 1996 - Dec 1998 G6850-60F**
SR20DET Kouki side skirt (front-left) Aug 1996 - Dec 1998 76853-60F**
SR20DET Kouki side skirt (front-right) Aug 1996 - Dec 1998 76852-60F**
SR20DET Kouki side skrit (rear-left) Aug 1996 - Dec 1998 76857-60F**
SR20DET Kouki side skirt (rear-right) Aug 1996 - Dec 1998 76856-60F**
SR20DET Kouki rear spoiler Aug 1996 - Dec 1998 K6030-60F25, K6030-60F26
SR20DET Kouki rear valence kit Aug 1996 - Dec 1998 H5910-60F**
SR20DET Rear valence kit Jan 1991 - Aug 1996 H5910-51F**
SR20DET Rear valence (left) Jan 1991 - Aug 1996 H5913-51F10
SR20DET Rear valence (middle) Jan 1991 - Aug 1996 H5911-51F10
SR20DET Rear valence (right) Jan 1991 - Aug 1996 H5912-51F10
SR20DET 180SX side glass (right) Jan 1991 - Jan 1995 83300-47F00
SR20DET 180SX side glass (right) Jan 1995 - Dec 1998 83300-47F01
SR20DET 180SX side glass (right) Sep 1997 - Dec 1998 83300-47F02
SR20DET 180SX side glass (left) Jan 1991 - Jan 1995 83301-47F00
SR20DET 180SX side glass (left) Jan 1995 - Dec 1998 83301-47F01
SR20DET 180SX side glass (left) Sep 1997 - Dec 1998 83301-47F02
SR20DET 180SX Rain guards Jan 1991 - Dec 1998 G3810-40F00
SR20DET Kouki front seat (back assy) Aug 1996 - Dec 1998 87600-60F00 Both sides
SR20DET Kouki front seat (cushion assy) Aug 1996 - Dec 1998 87300-60F00 Right side
SR20DET Kouki front seat (headrest) Aug 1996 - Dec 1998 86400-80F10 Both sides
SR20DET Kouki front seat (cushion assy) Aug 1996 - Dec 1998 87350-60F00 Left side
SR20DET Kouki rear seat (back assy) Aug 1996 - Dec 1998 88600-60F00
SR20DET Kouki rear seat (cushion assy) Aug 1996 - Dec 1998 88300-60F00
SR20DET 180SX Key (with 180SX logo) Jan 1991 - Dec 1998 KEY00-00135
SR20DET Zenki front turn signal (right) Mar 1989 - Jan 1991 B6120-44F00
SR20DET Zenki front turn signal (left) Mar 1989 - Jan 1991 B6125-44F00
SR20DET Chuki front turn signal (right) Jan 1991 - Aug 1996 B6120-50F00
SR20DET Chuki front turn signal (left) Jan 1991 - Aug 1996 B6125-50F00
SR20DET Kouki front turn signal (right) Aug 1996 - Dec 1998 B6130-60F00
SR20DET Kouki front turn signal (left) Aug 1996 - Dec 1998 B6135-60F00
SR20DET Front amber sidemarker (right) Mar 1989 - Dec 1998 26160-47F00
SR20DET Front amber sidemarker (left) Mat 1989 - Dec 1998 26165-47F00
SR20DET Kouki parking light (right) Aug 1996 - Dec 1998 B6170-60F00
SR20DET Kouki parking light (left) Aug 1996 - Dec 1998 B6175-60F00
SR20DET 180SX rear center light Mar 1989 - Aug 1996 26540-47F00
SR20DET Kouki tail light (right) Aug 1996 - Dec 1998 B6550-60F00
SR20DET Kouki tail light (left) Aug 1996 - Dec 1998 B6555-60F00
SR20DET Kouki tail light (center) Aug 1996 - Dec 1998 26540-60F**
SR20DET Kouki tail center (carbon?) Aug 1996 - Dec 1998 K0810-60F00
SR20DET Kouki rear trim panal Aug 1996 - Dec 1998 85230-60F00
SR20DET Navan steering wheel Jan 1991 - May 1995 D840V-11100
SR20DET Navan steering wheel (Hicas) Jan 1991 - May 1995 D840V-11130
SR20DET Momo steering wheel Aug 1996 - Dec 1998 D8400-C9901
Old 11-25-2008, 09:18 AM   #2
Myth
Just what I needed! Thx!
Myth is offline   Reply With Quote
View ALL DVD's View ALL Shirts View ALL DVD's View ALL Shirts View ALL Shirts View ALL Shirts
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
