Lsd
This is a discussion on Lsd within the TECH Discussion Forum forums, part of the TECH Discussion category; I heard you needed one to drift, or at least it'll make it easier. Is that true, because i was ...
Old 02-28-2004, 08:17 PM   #1
Cobra_R
Cobra_R's Avatar
Lsd
I heard you needed one to drift, or at least it'll make it easier. Is that true, because i was reading this description of an LSD for sale and it says it provides more traction to the rear, how does that make it easier to drift, you need less traction in the rear right?
Old 02-28-2004, 08:41 PM   #2
panda_3ight_6
Senior Member
panda_3ight_6's Avatar
A LSD or Limited Slip Differntal, Creates a locking action inside the Rear Differtal. Forcing both wheels to spin at the same speed.
They'res many differnt types and brands of LSD's,
1. Clutch Type (Cusco, Nismo others)
2. Hetical Type
3. Quafie (did i spell right?)
The main reason drifters use LSD is to keep the rear wheels spinning at the same time, to make better looking and more controlable drifts. A LSD will also help in the exit of a drift where a Open Diff would normally put power to one wheel, the LSD puts power to both.
Old 02-28-2004, 10:18 PM   #3
banged240_drift
what would be the main differences as far as performance between the clutch type and the quaife
im gettin lsd soon so im doin some home work
Old 02-29-2004, 12:00 AM   #4
Cobra_R
Cobra_R's Avatar
same here im trying to get one as well
Old 02-29-2004, 12:31 AM   #5
HondaHater
HondaHater's Avatar
me too
HondaHater is offline   Reply With Quote
Old 02-29-2004, 03:29 AM   #6
BeerBringer
Quiafe? Isn't that a manufacturer of LSD's just as CUSCO and KAAZ?
A Clutch-type LSD is what you guys need. All other types is more or less crap when it comes to drifting.
Go for Cusco or KAAZ they make the strongest LSD's.
BeerBringer is offline   Reply With Quote
Old 02-29-2004, 06:55 AM   #7
banged240_drift
yeah quaife makes, i think thier called gear diffs....beats me dont realy know anything about quaife
and theres also deft-force, they make a lsd specificly for drift..real aggressive, but from what i hear i wouldent put it on a daily driver
Old 02-29-2004, 03:40 PM   #8
raging panda
Quaife aren't bad, theyre just not as aggressive as a clutch type. The clutch type are very quick to engage, or lock up both wheels to make them spin at the same speed. Quaife are slower to engage making them less ideal for drifting. Quaife also feel a lot more like an open diff. The clutch type will make your car understeer when it locks up, but thats ok when youre drifting as it will end up in oversteer when you break the rear traction loose. The quaife will not cause understeer and are more ideal for auto-x.
Old 02-29-2004, 04:44 PM   #9
panda_3ight_6
Senior Member
Correct me if im wrong but a cheap way to make a LSD is to weld the differntal togreather? I'm thinking this for my car becuase its crappy and I'm broke??
Old 02-29-2004, 04:54 PM   #10
nissanguy_24
nissanguy_24's Avatar
that would give you a full locked differential, good for drag racing, never used one for drifting, but there suposed to suck when taking turns. sence one wheel needs to move at a different speed then the other.
Old 02-29-2004, 08:17 PM   #11
CRASHDRIVE
CRASHDRIVE's Avatar
To give you guys a basic understanding how LSDs works.
Here's a link:
http://auto.howstuffworks.com/differential.htm
this kind of explains the many kinds of LSD types.
Old 02-29-2004, 09:51 PM   #12
spinitsidewayz!
skidster
Send a message via AIM to spinitsidewayz!
kaaz's site also has a nice page that explains how their lsd's work
http://www.kaazusa.com/technology.asp
spinitsidewayz! is offline   Reply With Quote
Old 02-29-2004, 10:25 PM   #13
raging panda
welding the diff will be alright for when you are in the drift, but your exit will suck. And when you are driving normally, you will have bad control because the inner tire wants to go slower but you are making it go as fast as the outside tire. It is good for drag because no more peg leg burnouts and both tires bite off the line, but not good for turns. Basically its not a good idea for a drift car.
Old 03-01-2004, 12:31 PM   #14
delasoul909
that one guy...
delasoul909's Avatar
and welding it will only last a lil while... my friend did it and it broke within a month or two...
just my experience with it.... but its up to u... try it if u want...
delasoul909 is offline   Reply With Quote
Old 03-02-2004, 01:07 PM   #15
raemi
Send a message via AIM to raemi
i highly reccomend agianst bootlegging your car....if you dont have the funds for the parts you want. save for them and look for the best deal whenever you do have the cash....
raemi is offline   Reply With Quote
Old 03-02-2004, 01:39 PM   #16
banged240_drift
i guess if your car was track only..... but then if it were track only why skip on the nicer mods anyway?
