This is a discussion on camber kit within the TECH Discussion Forum forums, part of the TECH Discussion category; Do new suspension kits usually come with adjustable camber or do i need to buy an adjustable camber kit. Do ...
camber kit
Do new suspension kits usually come with adjustable camber or do i need to buy an adjustable camber kit. Do you need adjustable camber kits for the front and the rear or just the front, cuz i could only find camber kits for the front?
For the front, some coilover kits have upper camber adjustment plates, you can also use a front arm. In the rear, you can use an adjustable upper arm, or there are differnt links that can be changes out to change camber angles.
Most coilovers come with them but if there just struts you will be looking for them sepratley..
Here are mines for the front. |
