FC3S LSD question
This is a discussion on FC3S LSD question within the TECH Discussion Forum forums, part of the TECH Discussion category; I got an Fc and i was gonna put the stock FC LSD in it. Does anyone know if this ...
Old 03-01-2004, 04:11 PM   #1
Cobra_R
Cobra_R's Avatar
FC3S LSD question
I got an Fc and i was gonna put the stock FC LSD in it. Does anyone know if this would be a good LSD for drifting or should i go aftermarket?
Old 03-01-2004, 04:12 PM   #2
Chas
Chas's Avatar
The stock lsd is not as good as an aftermarket lsd. What model FC do you have, not all of the rearends are the same.
Old 03-01-2004, 04:27 PM   #3
Cobra_R
Cobra_R's Avatar
i have an 88 vert non turbo. some guy said he had an FC LSD that would fit on my Fc for like 125 and i figured the aftermarket ones are so expensive like 1 grand that i should go with this one.
Old 03-01-2004, 04:31 PM   #4
Chas
Chas's Avatar
It is better then an open diff, but now really what your looking for. It will hold you over for awhile though.
Old 03-01-2004, 04:31 PM   #5
Chas
Chas's Avatar
Old 03-01-2004, 04:39 PM   #6
Cobra_R
Cobra_R's Avatar
yea i was looking at a deft force LSD, it supposed to be specifically foir drifting, but its like 1200, and im only 17, i got 1200 saved up but i dont want to spend it all at once, i need to get a job.
Old 03-01-2004, 04:56 PM   #7
Cobra_R
Cobra_R's Avatar
the OEM FC LSD has 100,000 miles on it, you think it'll work for drifting.
Old 03-01-2004, 05:01 PM   #8
Weapon X
SHINJIRO
Weapon X's Avatar
Just find a GTUs clutch type 1.5 way lsd.
Old 03-01-2004, 05:47 PM   #9
Cobra_R
Cobra_R's Avatar
and where would i find one?
Old 03-01-2004, 06:04 PM   #10
driftfreak
GTUs dont have 1.5 way
heres the real *Censored**Censored**Censored**Censored*
get a S4 rear end out of a GXL
it has 4.10 gears and a cltch type LDS
all S5 LSD are VLSD and suck *Censored**Censored**Censored*
the miatia torsten will bolt into the rear gears of a NA rear end...but torstens are bad...
the GTUs has 4.30 gears but are hella rare..
Old 03-25-2004, 05:39 AM   #11
JunpoweR
JunpoweR's Avatar
Go aftermarket and go with a KAZZ but if ur pockets are thin then use a TURBO II tranny or a GTUs VLSD =)
Old 03-26-2004, 09:18 AM   #12
TP | sil-beer
TP | sil-beer's Avatar
Send a message via AIM to TP | sil-beer
TUrbo 2 one or GTUs would be a good start :]
my stock turbo2 one is dead so im gonna swap in a FD torsen unit...ill tell you how that goes once i get it all done
TP | sil-beer is offline   Reply With Quote
Old 03-26-2004, 09:30 PM   #13
Cobra_R
Cobra_R's Avatar
cool thx
