240sx One Headlight not Going on...
This is a discussion on 240sx One Headlight not Going on... within the TECH Discussion Forum forums, part of the TECH Discussion category; My left headlight works perfectly, but the right side won't go on. Nothing wrong with the bulb. Both high beams ...
Old 05-04-2009, 12:46 AM   #1
hachirolla808
Send a message via AIM to hachirolla808 Send a message via Yahoo to hachirolla808
My left headlight works perfectly, but the right side won't go on. Nothing wrong with the bulb. Both high beams work, but no right low beam.
Thinking it might be the switch, but don't have spare to check. Could anyone give me some advice.
hachirolla808 is offline   Reply With Quote
Old 05-04-2009, 02:00 AM   #2
akuma S14
akuma S14's Avatar
Send a message via MSN to akuma S14
well since it is a dual filament bubl i suggest switching bulbs from left to right... then check the wiring and fuses.
KAAZ USA
JIC Magic
Exedy Clutch
Toyo Tires
Racecool coolant
NRG
Apache Racing
Hiwosport silicone hose
www.driftbuffet.com
www.apdrift.org
akuma S14 is offline   Reply With Quote
Old 05-04-2009, 10:36 AM   #3
eomund240
eomund240's Avatar
+1.
What model of 240? The S13's are notorious for having the wiring get loose at the headlamp unit itelf. One thing to do is while you have the lights on, wiggle the wires right at the asseble, even possibly unplug and replug them back in. It's even possible that you might have an open in the line somewhere, but check the other stuff first being as it's much easier.
