This is a discussion on 240sx open diff conversion within the TECH Discussion Forum forums, part of the TECH Discussion category; i was wondering how i can convert it to an lsd. money isnt a problem to me i just need ...
Thread Tools |
Rating:
Display Modes |
i was wondering how i can convert it to an lsd. money isnt a problem to me i just need all available options; i just know to weld it. or rip it out of another 240 with an lsd. But is it that simple?
"Its not what you drive, its what drives you"-Initial D |
#2 | |
Kaaz USA 13841 West St Garden Grove, CA 92843 USA Tel: 1-888-522-KAAZ (5229) Tel: 714-554-4333 Fax: 714-554-4334
KAAZ USA JIC Magic Exedy Clutch Toyo Tires Racecool coolant NRG Apache Racing Hiwosport silicone hose www.driftbuffet.com www.apdrift.org |
If your pumpkin(dif housing) doesn't have a finned aluminum cover, find one that does. Rear ends get very hot without a posi(lsd), a loaded one will burn up. Some 240's don't have a finned cover, your posi won't be able to handle the heat and will fall apart.
That is somewhat true, the heat is excessive but I have been running the same KAAZ diff in my R32 for about 3 & 1/2 years now. No Finned cover. I just keep the regular cover clean and change the oil with genuine KAAZ oil frequently. Never had a problem.
Do i really have to do the figure eight? I have to do it in a parking lot then...
#6 | |
like anything else.... engine break in, brakes, etc.....
just wondering did you tow it to the area big enough or did you just drove it?
you can just drive it nice and easy i think it will be ok
no hard turns and no drag launches.... get to your parking lot, do firgure 8s in until you pass out... then go have fun. I recommend changing your fluid quickly after break in. (as does KAAZ)
Driving it isn't going to do any damage to it. The point of breaking it in is exactly the same as breaking in a clutch or brake pads: you want to make sure the friction surfaces are completely bedded so when you actually use them to their fullest extent, you won't damage them. When you put a new clutch in, do you tow the car until it's broken in? Do you tow a car to break in your brake pads?
Just drive to a parking lot and do your figure 8s. When you're done, go home and change your gear oil. Then go get sideways. |
wow mike... thanks for paraphrasing me in such a kind and generous manner
| Tags |
| 240sx |
