This is a discussion on ???LSD, Spool Locker, Welded diff, welded spider gears??? within the TECH Discussion Forum forums, part of the TECH Discussion category; Ok so I have been using the ever elusive SEARCH BUTTON! LE GASP!! I have been learning a lot, but ...
Ok so I have been using the ever elusive SEARCH BUTTON! LE GASP!! I have been learning a lot, but I keep hearing these terms. Limited slip differential (which I understand how that works), but then I hear these other terms like spool locker, welded diff, welded spider gears. Are all these things doing basically the same thing, just different ways of getting the job done???
Spool and locker are not the same thing. There are multiple types of lockers. Welded and welded spider gears are the same thing. Welded and spool act the same but a spool is the proper way to go. They don't all do the same thing except for spool and welded. All of them make it easier to get sideways but that's the only similarity.
If you're on a tight budget, welding is the way to go but you gotta know how to weld it.
I'm just a fan that likes to see cars going sideways, tires up in smoke, putting smiles on everybody's faces ~understar |
Yep.
Here's my diff. Note how the gears are welded to the carrier itself. ![]() ![]() ![]() You can kinda see how i packed weld between the gears in this last one. Lots of heat, crank the gas and turn the wire feed up! This was the first one i welded. The gears that are adjacent to the diff bearings have 3 overlapped beads on each side, the gears on the same sides as the bearings have 2 beads. I melted the gears together first and packed as much wire as i possibly could in before i started welded the gears to the carrier. Excuse the crappy craftsmenship. This was the first thing i had welded in over 4 years. I did two the same day and the second one i sold looked much better. This went into my car about 2 months ago and i've yet to put the beating on it but my other welded is still going strong on the guys car so this one should hold up fine too. Last edited by NoPistons!; 05-03-2010 at 01:01 AM. |
i believe that the uglier it looks, the better itll hold up
![]() plus its not like your going to see it, as long as you penetrate it good enough youll be fine. |
In the UK we tend to weld steel plates between the spider gears too for added strength. Do be careful though, these diffs put more stress on the rest of the drivetrain.
Yep. Plate it if you can.
looks like a FC diff. your stub axle will break before the weld does, it looks plenty strong.
plate=bad.... my friends and i both had plates also welded into the teeth then ended up falling out on mine getting stuck between my ring gear and pinion that was a fun event. my friends just broke free but the plates didnt come out of the carrier. When welding a diff its all about penetrating the metal of the spider gears if you do that its solid and you'll break axles and driveshafts before the rear gives out
get loose |
Bad welding right there. Imagine if just the gears were welded up, they'd be more likely to spit some of that poor welding out and that will lock up your CWP as surely as a plate will.
Tell that to pbm/psm.
Yes, it's an fc diff. Stubshafts and diff should be fine. 205's with a considerable stretch and i'm only pushing 100whp of 1.3L bone stock n/a 2 rotor juice. |
if its welded right it should never break
http://e36driftbag.blogspot.com/ 1999 Toyota Chaser Turbo (Germany) 1998 BMW 328is S52 swap (USA car) 199? Nissan Cefiro Turbo (Japan car) Hold my Dragon! |
