This is a discussion on 88 FC engine compare to 89 FC engine within the TECH Discussion Forum forums, part of the TECH Discussion category; Are the engines in the s4 different then the s5 engines? For example, will a s5 cold air intake fit ...
Are the engines in the s4 different then the s5 engines? For example, will a s5 cold air intake fit on a s4?
it'll fit
Pita didnt like my avitar
lots of stuff..
why dont you try searching the RX7 web pages for information.... www.teamfc3s.org www.rx7club.com www.nopistons.com www.clubfc3s.com ect its not hard to search.. |
#5 | |
ww.SFLDrifter.com
S5 has lighter rotors than S4 and has a 8000 redline instead of 7000 in S4.
S4-146hp S5-165hp |
chris@SPD Racing
the s4 and s5 MAF are not the same
#8 | |
#9 | |
correction 160 hp for S5 =) Engine Specifications Engine Type: Twin Rotor 13B Normally Aspirated Displacement: 1308cc/80ci Compression Ratio: 9.7:1 Output(hp): 160bhp @ 7000 rpm Torque: 140lb-ft @ 4000 rpm Fuel Supply: 4 Injectors via Electronic Fuel Injection |
#10 | |
True, you need an adapter to bolt the filter onto a S4 and the filter will bolt directly onto the S5 sans adapter.
