This is a discussion on How to Cool down my Miata within the TECH Discussion Forum forums, part of the TECH Discussion category; My miata has been overheating a lot. I dont know if its cuz its hot in SoCal or maybe it ...
My miata has been overheating a lot. I dont know if its cuz its hot in SoCal or maybe it needs some cooling gear. What do you guys recommend. So far all it has a intake and thats it. I'm thinking new radiater and fan but not sure. Can I get some opinions please.
#2 | |
Re: How to Cool down my Miata
#3 | |
lemonade |
do you have a fan pushing air though the radiator right now? I didnt for a while, but its not as hot up in washington all the time. Try a high pressure radiator cap, an electric fan, a lower temp thermostat, and if those dont work, a bigger radiator.
Pita didnt like my avitar
drop vent hood...good radeatior..and better front aero parts....
If you have a stock miata, aside form the air intake and its overheating in this relatively mild temperature increase in so cal, (im also from southern california) then something is probably broken or worn out. Thermostat is a good starting point. I wish i could be more helpful aside from saying that but im really not that knowledgable of a mechanic.
Senior Member
As for the aftermarket\custom parts, A high proformance radiator would work well, along with a thermostat, (Im not sure how a high pressure radiator cap would cool the car more), also removing the plastic\rubber seal around the hood that touches the firewall will allow more airflow and in turn cool the engine. Taking out the grille and moving other cooling things, like oil coolers or transmisson coolers helps too.
Remeber you my just need a coolant flush... |
OMG the ground's white!
Is this a something broken overheating or is it just it runs a little warm overheating.
If the needle goes off the guage, something's broken, most likely the thermostat. Just get a new one and throw it in, problem solved. If your car has a fan, it should run. If it doesn't, then that may need to be replaced. If it's just a little warm type of overheating, then follow what others have said. |
Get a aluminum radiator and electric fan..
also try a better thermostat that opens at a lower temmp.. Mabey use evans cooling fluid.. Also mabey Junpower CustoM hood lifts =) Works on my fc =) |
#10 | |
Check to make sure the raditior is clean, change out the fluid, new cap and new thermostat. Hood vents and maybe a bumper vent should really cool things down.
ƒhƒŠƒtƒg
Stock thermostats tend to go easily,since your overheating now,it's probably already gone anyways.Just take it out when you get the chance and test it out(using water to find its operating temp).If that's gone,buy a good aftermarket thermostat and make sure it's fail safe.I doubt you have any leaks,it's a little hard not to notice them.Check out the thermostat though.
Alright,when you take the thermostat out,check for a printed temperature.This is the temperature it opens at.Now take the thermostat and a thermometer(one that can read above 100ºC at least).Now boil the water as high as needed,holding in the thermostat while monitoring the water temp.If the thermostat doesn't open at the printed temp,you know it's fried.Pretty simple,and could save you lots of time,money,and manpower. |
amateur
hahaha, the car i drive doesnt have problems like that. no radiator! hehehe. but i agree with what everyone has been saying, thermostat
DRFT 2NR
miatas tend to overheat alot because of no real air flow to the radiator not to mention the radiators themselves are pretty small. 9 times out of 10 it's the thermostat. A little advise: go with a higher temp thermostat. They really stay alot cooler and way below normal temps. If you have the money upgrade your radiator also.
#15 |
First, bleed the cooling system. Air bubbles in the system will reduce efficiency dramatically. Coolant is cheap, so you might as well do it. If that doesn't do it and you're poor, then buy some Redline Water Wetter. And... if that doesn't do it, then I think it's the thermostat.
#16 |
geeze peeps u don't need all that extra aftermarket crap for a stock miata......the likely culprit is the thermostat...if not then the fan prolly isn't coming on is simply dying out......and then maybe its the radiator itself that needs to be flushed......and when u say overheat do u mean just daily driving overheating or doing donuts and what not overheating.....
#17 |
Turbo MX-5
awhile back i was having overheating problems with my miata and the cause in my case was a bad radiator fan.
the main fan (not the one that comes on with the A/C) had a bad motor. it would either not come on or not spin very forcefully. i got a junkyard replacement fan and now the car never overheats. i'm running a GReddy turbo kit and the car doesnt overheat at all so the stock cooling hardware should hold up unless you go crazy with mods and super high hp. |
#18 | |
