Rebuild the Rotary or Swap for Drifting?
This is a discussion on Rebuild the Rotary or Swap for Drifting? within the TECH Discussion Forum forums, part of the TECH Discussion category; Hello. I have a S5 T2 that need to be rebuilt. I love rotaries and want to start with a ...
Old 02-11-2011, 11:47 AM   #1
Linguo415
Hello. I have a S5 T2 that need to be rebuilt. I love rotaries and want to start with a relatively lower powered car. It will cost about 5k with new Rotor housings oem seals and a huge oil mod. then I would get fuel management. Some other mods and then I want to go and get sideways. Anyway there is no guarenty that the engine will last under drift application and driving it to and from the events.
Here is the alternative i am thinking about.For a liittle more i can put in a 1 or 2jzgte. These engines are really strong from the factory. The cars behavior would change but i can learn to manage i suppose. This is the only swap i will consider. Even talking like this is taboo in the rotoary world. Im not much of a purist but i wouldnt usualy think about swaping a rotary out vs in. My mo is the drift. i want to get good at it and want it to last. 5k is a lot to spend for me. idk about you guys but im not rich. Lol
Any advice or suggestions would be great. Thanks guys.
Linguo415 is offline   Reply With Quote
Old 02-11-2011, 02:37 PM   #2
Cavi Mike
Why is that the "only engine you will consider?" That just makes you sound ignorant. The engine is far too long, way too heavy and would require WAY more than your budgeted $5G to make work. And if you want to "get good at" drifting, you should already be deep in the learning curve by now. Power doesn't give you skill. In fact, it's the very opposite.
Old 02-11-2011, 06:51 PM   #3
Bebop
Send a message via AIM to Bebop
Keep the brotary.... they are the funnest most easy motors to build other then air cooled VWs.
Bebop is offline   Reply With Quote
Old 02-11-2011, 06:56 PM   #4
INFO
INFO's Avatar
Here is the alternative i am thinking about.For a liittle more i can put in a 1 or 2jzgte. These engines are really strong from the factory. The cars behavior would change but i can learn to manage i suppose. This is the only swap i will consider. Even talking like this is taboo in the rotoary world. Im not much of a purist but i wouldnt usualy think about swaping a rotary out vs in. My mo is the drift. i want to get good at it and want this to last. 5k is a lot to spend for me. idk about you guys but im not rich. Lol
We produced this DVD
http://store.driftingshop.com/2jzrxfdswdvd.html
DRIFTING.com @ FACEBOOK
DRIFTING.com @ TWITTER
DRIFTING.com TWITTER
Old 02-11-2011, 07:00 PM   #5
INFO
INFO's Avatar
Budget Reference
240SX 1JZ/2JZ Swap
2JZ/1JZ SWAP PARTS LIST
2JZGTE MOTOR includes shipping & 6 month warrenty $2600
Transmission parts to piece together a r154 US Spec transmission from Toyota Supra Turbo 1989 to 1992
1JZ Bell housing $375
1JZ flywheel $275
ACT clutch kit 650 FT torque 6 puck (option for our install) $700
SHIFTER EXTENSION PLUS CORE $250 + $200
2JZ SWAP KIT PLUS CORE $1500 +$200
2JZ PLUG N PLAY WIRING $450
CLUTCH LINE SS KIT $120
FUEL LINE KIT $130
A/C KIT (option for our install) $750
THROTTLE CABLE BTACKET $45
JDM 2JZ 3inch DOWN PIPE ADAPTER $100
WATER PUMP $150
TIMING BELT $28
SERPENTINE BELT $30 UNIVERSAL SPEEDOMETER INTERFACE $79.95
UNIVERSAL TACHOMETER INTERFACE $79.99
WALBRO FUEL PUMP $100
KOYO RADIATOR WITH UPPER INLET MODDED $450
SPAL FANS $200
FAN CONTROLLER $100
2JZ 4IN INTERCOOLER KIT $650
PULLEY SET W/P,P/S,ALT $135
MISC. PARTS HEATER HOSES, RAD HOSES, CLAMPS $275
Old 02-11-2011, 08:11 PM   #6
Cavi Mike
Ugh. Figures.
Old 02-11-2011, 08:25 PM   #7
Linguo415
Hahaha. Brotary. i really want to but im just affraid of it blowing up sooner than later. i know its all about the tuning and set up. I dont think ill boost it much.
Old 02-11-2011, 08:29 PM   #8
Linguo415
I know power doesnt give you skill. Im after longevity. thanks for the ignorant comment. Nice. what do you recomend?
Old 02-11-2011, 08:36 PM   #9
Bebop
Man up, read a book, look up some data. You will find out that the 13B if built and tuned properly is just as reliable as any other 90s Japanese 4/6 cyclinder.
Old 02-11-2011, 08:50 PM   #10
Linguo415
^ Bro ive done sooo much research already. No joke. for the last year and ahalf or so. Lol They are great engines and I love them! Im just trying to see what my option are right now. Im not into V8s either. the 1j or 2j are really strong and last a real long time. Its the best Japan made engine.
It wont be an Rx though. Thats the soul of these cars its engine. Its what makes them one of a kind so to speek.
Old 02-11-2011, 09:11 PM   #11
INFO
INFO's Avatar
We also produced a Rotary Rebuild DVD with Formula D driver Kyle Mohan from Mazdatrix.
http://store.driftingshop.com/ma13broentdv.html
Old 02-11-2011, 09:23 PM   #12
INFO
INFO's Avatar
would you swap in the motor yourself?
Old 02-11-2011, 09:30 PM   #13
Linguo415
^Um im thinking yes. with help. Otherwise I have someone that wont charge a ton to do it.
Old 02-12-2011, 02:23 AM   #14
Cavi Mike
Rotaries have no problem with longevity as long as the owner has some intelligence.
Old 02-13-2011, 01:32 AM   #15
Linguo415
^ Goood atleast you didnt say v8. lol
i
Old 02-13-2011, 01:41 PM   #16
mazdized
If your budget is $5 then stick with 13B. If you are happy with 300ish whp beat it all day no worries at all then stick with the 13B. But if you are looking at 400+ or may be high 400s and still keep the car light then LSX V8 is the way to go.
mazdized is offline   Reply With Quote
