This is a discussion on (PART #2) Drift Suspension Setup By Mike Kojima within the TECH Discussion Forum forums, part of the TECH Discussion category; (PART #2) Drift Suspension Setup By Mike Kojima In part one of our series we spoke about the importance of ...
Thread Tools |
Rating:
Display Modes |
![]() (PART #2) Drift Suspension Setup By Mike Kojima In part one of our series we spoke about the importance of good suspension which is probably the first major step in setting up a car for drifting. Although the suspension is really important, perhaps just as important is a good limited slip differential. To read more on suspension set up and part one, check out this section. “The Ultimate Guide to Suspension and Handling” LSD One of the most critical parts of a drift car that isn’t really part of the suspension but worth mentioning here is an LSD or limited slip differential. Without an LSD, it is really hard to get a car to drift. An LSD diff is one that locks the two drive wheels together under power. When the wheels start to spin on a car with a regular diff, all of the power is transferred to the wheel with the least grip so only one tire spins, in a turn it would be the inside rear wheel. No power is transferred to the loaded outside wheel and it does not spin. This makes it hard to get the car to slide by using the engines power. CONTINUE HERE FOR THE FULL FEATURE http://www.motoiq.com/magazine_artic...up-part-2.aspx
DRIFTING.com @ FACEBOOK DRIFTING.com @ FACEBOOK DRIFTING.com @ TWITTER DRIFTING.com TWITTER DRIFTING.com STORE DRIFTING.com Tel.(877) 786-7694 The BEST WAY to reach DRIFTING.com is by calling between 11AM-5PM (PACIFIC STANDARD TIME) If you are on the EAST COAST then call at 2PM. If you reach our voicemail then CALL BACK AGAIN between 11AM-5PM (PACIFIC STANDARD TIME) |
| Tags |
| drift suspension setup, drift suspension tuning, tire pressure for drifting |
