(FEEDBACK) SR20DET Main Bearing Clearance, SR20DET Piston Ring End Gap?
This is a discussion on (FEEDBACK) SR20DET Main Bearing Clearance, SR20DET Piston Ring End Gap? within the TECH Discussion Forum forums, part of the TECH Discussion category; SR20DET Main Bearing Clearance, SR20DET Piston Ring End Gap? Which clearances have you OR your friends used in the past? ...
Old 01-24-2012, 02:03 AM   #1
INFO
INFO's Avatar
Which clearances have you OR your friends used in the past? And how much boost were you running?
Nissan Bearing Clearances
http://www.peak-performance.net/content/view/183/98/
CP Gap Chart
http://www.cp-carrillo.com/LinkClick...Ls%3D&tabid=83
http://store.driftingshop.com/srmobudvdo15.html
SR20DET Main Bearing Clearance,SR20DET Rod Bearing Clearance, SR20DET Ring Gaps, Nissan Bearing Clearances, SR20DET TOP RING gap, SR20DET SECOND RING gap, SR20DET OIL RING gap, SR20DET boost
DRIFTING.com @ FACEBOOK
DRIFTING.com @ TWITTER
DRIFTING.com TWITTER
Tags
main bearing clearance, nissan bearing clearances, sr20det boost, sr20det main bearing clearance, sr20det oil ring gap, sr20det ring gaps, sr20det rod bearing clearance, sr20det second ring gap, sr20det top ring gap
