This is a discussion on DriftXtream was right, bent control arm within the TECH Discussion Forum forums, part of the TECH Discussion category; You called it DX... I just got back from out side, looking under the car, The tension rods are fine, ...
You called it DX... I just got back from out side, looking under the car, The tension rods are fine, but the passanger control arm is bent up, right in the middle, ill get some pictures up soon if i can.. PDM sells some new ones for 50 bucks. and some with poly bushings already pressed for 95, i figure ill order up two, in a few days.
http://www.pdm-racing.com/products/pdmcontrolarms.html I didnt see anything else that looked damaged except that, but if i find anything else ill say so. Thanks for the help man. |
How did you pull this off?
Pimp daddy D
What up SMC
Glad to help, and thank god you found it in time. Id hate to been in there when it desided to retirer. Good luck hope you get it fixed soon. Are you down with DONG |
