does the tranny bolt up????
This is a discussion on does the tranny bolt up???? within the TECH Discussion Forum forums, part of the TECH Discussion category; if you do a sr20det conversion does your ka24de tranny bolt up or do you need an adapter plate????...
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 04-07-2004, 04:05 PM   #1
raiden_flyboy
raiden_flyboy is offline   Reply With Quote
Old 04-07-2004, 04:24 PM   #2
raging panda
you need to change the bellhousing to make the sr20 bolt up to the ka tranny, thats just about as hard as finding a sr20 transmission.
Old 04-07-2004, 05:22 PM   #3
raiden_flyboy
what about finacially is it cheaper to find that bellhousing or what about an adapter plate???
Old 04-07-2004, 06:49 PM   #4
quickstyleRPS13
Junior Member
Send a message via Yahoo to quickstyleRPS13
there is no adapter plate and even if there was the gearing would be all fu cked up. the ka tranny is for a na motor it is better to use a tranny that is geard for a turbo motor. so to sum it all up you need an sr tranny. i have a s13 black top with tranny,harness and ecu if your inerested. $2500 plus shipping
quickstyleRPS13 is offline   Reply With Quote
Old 04-08-2004, 05:05 PM   #5
raiden_flyboy
well does the driveshaft fit into the sr tranney?
Old 04-08-2004, 07:04 PM   #6
quickstyleRPS13
Junior Member
yes...
Old 04-09-2004, 08:28 PM   #7
Chas
Chas's Avatar
Yea the drive shaft is the same thing, all you need is the SR tranny.
Old 09-24-2004, 10:15 AM   #8
Hubert Young
DRIVER
Hubert Young's Avatar
Send a message via AIM to Hubert Young Send a message via Yahoo to Hubert Young
Sorry to dig up old thread. But has anyone done a bell housing swap? What needs to be done to make it work? I just took a KA tranny off a DOHC engine. I heard that the gear ratio is actually the same as the SR.
Any information would help. Thanks.
Hubert Young
KORE 8 Films
Hubert Young is offline   Reply With Quote
Old 09-30-2004, 01:03 PM   #9
Luv_piece
Gear ratio is very close to the SR. Not so different that you can feel the difference.
Luv_piece is offline   Reply With Quote
Old 09-30-2004, 01:40 PM   #10
GRiDRaceTech
GRiDRaceTech's Avatar
1-4 are identical. SR's fifth is different.
