This is a discussion on fuel system within the TECH Discussion Forum forums, part of the TECH Discussion category; on an 89 240sx (KA24E) how do i reliev the fuel system pressure?...
fuel system
how about setting up a kill switch for the power going to the fuel pump..
pull the fuse under the hood to the fuel pump, its labeled. Then, just crank your engine a few times until it dies, you're burning the fuel left in the fuel lines, then you have to pull the fuel rail off, some gas will come out, but not too much.
man thanks alot i need to replace my injectors
any advice on what size? stock motor.....i was just gonna go with new stock units |
either the new stock ones, or venom makes injectors that are good, not sure on pricing though, doesn't really matter unless you plan on turboing it later or something.
Get something with a little higher flow rate, but nothing to crazy.
