Turbo Maintenance
This is a discussion on Turbo Maintenance within the TECH Discussion Forum forums, part of the TECH Discussion category; Hey whats up guys. I was just thinking this over and I really wanted to know all the things that ...
Old 04-12-2004, 05:03 PM   #1
turbo_blitz21
Turbo Maintenance
Hey whats up guys. I was just thinking this over and I really wanted to know all the things that I need to do to keep my turbo live and boosting. I heard that oil builds up in the turbo and causes it to work bad and that you should use a boost controller with a turbo to let it cool down and spool up and work well but I don't really know too much on the topic. Any good info is good. Please don't give lame a$$ answers that don't make sense and please know what your talking about. Thanks!
Old 04-12-2004, 09:42 PM   #2
hokiruu
hokiruu's Avatar
Send a message via AIM to hokiruu
OK, first of all boost controllers don't keep your engine running to cool it down. A turbo timer does that and so does just sitting and letting your car idle for a minute after a run. Boost controllers, whether manual or electronic, cheat pressure away from the wastegate,"tricking" the turbo to produce more boost. "Spooling up" is not really the main thing you're interested in with a boost controller but rather the amount of pressure it is supplying. often, the more boost, the more lag, but not always. the gain setting on electronic boost controllers can help this, but that's a whole different thing. regarding keeping your turbo happy overall: using oil catch cans can help out with keeping excess oil from being routed back in (i'm soo close to buying one but am reluctant to pop $90 for one with my hard saved $). Turbo timer is great, and don't forget to let your engine warm up. that way your oil has the best lubricating properties possible. hope this helps but honestly i think you ought to dig a little deeper for your info. study automotive systems and read manufacturer's product descriptions and it'll be pretty self explanitory. boost on!
hokiruu is offline   Reply With Quote
Old 04-13-2004, 04:25 AM   #3
driftxtreem
Pimp daddy D
driftxtreem's Avatar
Just want to add to the great post above.
Choose your oil well. Look at the turbo manufactures recomendations as well as you engine manufacture recomendations. Some people swere by synthetics and others mineral based (like out the ground stuff) you should choose a oil that is compliant with both as well as grades. A heavy oil may slow your turbo do to heavy oil on the berring. and a light oil might not supply your engine berrings with sufficiant lubrication. We could talk for ten pages easyely about oil.
I built a jet engine with a truck turbo the thing is huge. With regular sae5w20 the thing wont spool up freely when I light it up. I actuly found some jet aircraft oil and the thing screems. Now working on the after burner. Engines are fun but when you can break the sound barrior in you front yard then your learning.
Old 04-13-2004, 01:35 PM   #4
raging panda
about the oil catch can thing, you dont need to drop a ton of money to have one, they just look pretty. All you need is some kind of can or someting ( my friend uses a paint can) and some tubing. Drill holes into the top of the can, add some kind of nipple to attatch the hose to and there you are. It just has to be something in line between the valve cover and the intake, doesn't matter what it is as long as it wont melt and it wont let any oil into the intake.
Old 04-14-2004, 02:31 AM   #5
Ex-Cat
Flight Lead
Ex-Cat's Avatar
DX, what kind of engine did you use? As a side note, since you love to get technical with other people, you can't actually break the sound barrier in your front yard or anywhere for that matter unless you're moving.
Ex-Cat is offline   Reply With Quote
Old 04-14-2004, 04:56 AM   #6
CrazyHawaiian
Sample One Time!!
CrazyHawaiian's Avatar
Install an oil cooler
Old 04-14-2004, 05:01 AM   #7
driftxtreem
Pimp daddy D
What could you speek up please im hard of hearing yea I know but its a turbo I built into a jet engine the thing screems. Dont know what rpms its tuning yet still working on the photocell to get an acurate reading but hell how many guys own a jet engine little lone built one out of scrap.
Old 04-14-2004, 07:51 AM   #8
CrazyHawaiian
Sample One Time!!
Man I'm 99% sure if I tried to build a jet engine it would explode. What do your neighbors think? I was thinking it would be cool to only turn the jet engine on during holidays and rev it up to let them know how happy you are. Your neighbors will love you!!
Old 04-14-2004, 02:50 PM   #9
turbo_blitz21
Yeah havin a jet engine in your yard is tight I need to do that!
Old 04-14-2004, 04:30 PM   #10
driftxtreem
Pimp daddy D
I dont know I can never hear what they are saying. And yes you can blow up doing this. Does 5 foot crater help in the analagy. I started with propane for fuel, now Im running strait keroseen and Im lovin it,
Old 04-14-2004, 05:41 PM   #11
Dirty85
i saw videos of ppl who put turbo jet engine on go karts and run them around......kind of a waist of money by the looks
but who can say they have a jet kart?
Dirty85 is offline   Reply With Quote
Old 04-14-2004, 08:12 PM   #12
Ex-Cat
Flight Lead
Ex-Cat's Avatar
^ I have two jets on the back of my plane, does that get me any bragging points? haha
Old 04-14-2004, 09:36 PM   #13
driftxtreem
Pimp daddy D
2 if you made them 1 just for having them
