This is a discussion on miata/mx-5 tire setup? within the TECH Discussion Forum forums, part of the TECH Discussion category; which of the following is a good size for the stock miata 14x6.5 rim to be used for drifting? 1. ...
1. 195/50/14 2. 195/55/14 3. 195/60/14 4. 205/50/14 5. 205/60/14 |
I know that they came with 14's, But i'd at least get a set of stock or aftermarket 15's. A slightly thinner sidewall on the tire is good because it will flex less then a tall one. With that said, imagine a 14in wheel with 50 series tire on them, it will also lower the car in a bad way because you are more likely to scrape/hit bump stops tec. Remember, you car has a 4x100 hub.... very very very common size. 205/55/15 or 205/50/15. Like i have mentioned I have 16" 's and run 205/40/16 = no sidewall flex. I am going to use a set of 14's tonight to drift with195/60/14 's and i'll let ya know how the sidewall hold up.
'aight thanks. how are the 16" on the car, enough power to spin them?
well, with the 16's on a 1.8 (much more power stock for stock over a 1.6), i can get 1st gear spin in the dry and 2nd in the wet.
Well, after last night, the 14's i have on the back w 196/60/14's held up quite nicely... i was suprised how little sidewall flex there is. I'll post pics of my car later in the current set-up it on. |
yeah my 14's did 'aight last night too! i was suprised at the little amount of sidewall roll too.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Advanced Suspension Setup; (Toe? Camber? Spring Rates?) Learn here! | theflatlander | TECH Discussion Forum | 36 | 10-19-2007 02:11 PM |
| gt4 car list. | snowblind | Off Topic Forum | 35 | 09-17-2004 08:25 AM |
| Gran Turismo 4 | S13_Steve | Off Topic Forum | 87 | 08-15-2004 12:33 PM |
| WARNING: "Photo Contest Scam" | DropTopDrifter | General Chat (DRIFTING Discussion/News and SITE Updates) | 36 | 04-04-2004 05:45 PM |
