need 5sp
This is a discussion on need 5sp within the TECH Discussion Forum forums, part of the TECH Discussion category; any body here know what its gunna take for a aouto to 5sp. conversion for my newest 240? I figure ...
Old 05-11-2004, 10:39 PM   #1
Dori Master
Send a message via AIM to Dori Master
need 5sp
any body here know what its gunna take for a aouto to 5sp. conversion for my newest 240? I figure a tranny,drive shaft,and possibly rear end.
Dori Master is offline   Reply With Quote
Old 05-11-2004, 11:30 PM   #2
nissanguy_24
nissanguy_24's Avatar
the rear end and drive shaft should be fine. Im fixing to do this my self so i've been reading up on it. You should just need the transmission and the hydrallics to run it. Not tomention the clutch and brake pedal to install. And everything that goes with making those run.
Old 05-12-2004, 04:09 PM   #3
Dori Master
Thumbs up
thanx pawtna,let me know how it gose. My fiscal policy is will hold be holding me back for a while,btw any one know where i can get ahold of a **CHEAP** ka24 header?
Old 05-12-2004, 04:12 PM   #4
MrodDrft
Dorifto Pic King
MrodDrft's Avatar
Send a message via AIM to MrodDrft
Wal*Mart
MrodDrft is offline   Reply With Quote
Old 05-12-2004, 08:22 PM   #5
Dori Master
Yahh...I mean no.
Old 05-13-2004, 12:22 PM   #6
shutUPandLEARN
here's a list. It's really easy to do. Done it a couple times.
-5 speed brake pedal
-5 speed clutch pedal
-clutch fluid reserviour
-clutch fluid hard lines
-clutch soft line
-slave cylinder
-throw out bearing
-pilot bearing
-clutch set
-flywheel
-tranny (I hope you remember this one)
-5 speed harness, or make the auto one fit (easy to figure out)
-drive shaft (get complete drive shaft, both pieces, don't piece them together from seperate cars)
-shifter
-shift boot
that should be all of it.
edit: auto and 5-speed use different sive drive shafts on 240s
shutUPandLEARN is offline   Reply With Quote
Old 05-13-2004, 12:33 PM   #7
hachiroku-fc3s
hachiroku-fc3s's Avatar
...drive shaft should be fine...
Huh?
Old 05-13-2004, 01:43 PM   #8
Dori Master
Tacaomatose/Dori Whore
hey hachi- did driftcentrel send you to spy? j/k ,Dosent the shaft have to be shortened like 1.5 in?
