drift clutch?
This is a discussion on drift clutch? within the TECH Discussion Forum forums, part of the TECH Discussion category; Just wondering, is there a specfic type of clutch thats better for drifting then others?...
Old 05-14-2004, 05:39 PM   #1
Cobra_R
Cobra_R's Avatar
drift clutch?
Old 05-14-2004, 06:17 PM   #2
180onthebricks.
bOrrOsTYlez
180onthebricks.'s Avatar
Send a message via AIM to 180onthebricks. Send a message via Yahoo to 180onthebricks.
clutches are often choosen by how much the engine hp is
180onthebricks. is offline   Reply With Quote
Old 05-15-2004, 10:52 AM   #3
raging panda
yea, it really depends what you want too. If you run a stock/aftermarket replacement, it will be nice to drive everyday, but it will suck when you start drifting and it starts slipping. Then again, a six puck clutch will be awsome for drifting because when you drop it, you will have immediate response to when you clutch kick and your rear end breaks loose, but daily driving will suck, and your left leg will get real buff. I never had a problem with a stock clutch for a while, but if I would drift for more than 5 or so minutes at a time it would start to overheat and slip.
Old 05-15-2004, 11:04 AM   #4
Weapon X
SHINJIRO
Weapon X's Avatar
A racing clutch wont necessarily suck for daily driving. For instance, I've got a Centerforce Dual Friction clutch on my car. The pedal pressures is really light but the thing grabs like a mofo. It's not that uncomfortable to drive with at all, the only thing is sometimes it chatters in first gear.
Old 05-15-2004, 11:19 AM   #5
raging panda
im not talking all clutches, i went to each extreme. I know a guy who has a six puck in his hachi, he doesn't like traffic from what I hear. If you have a upgraded street/strip clutch, generally they arent that bad. But then, those will overheat way before the six puck will, and they dont grab as well either.
