Must Know 240SX Engine Idea's and Information
This is a discussion on Must Know 240SX Engine Idea's and Information within the TECH Discussion Forum forums, part of the TECH Discussion category; Can this please be a sticky?? But here it goes.. all the info for engine swaps and wiring and codes ...
Thread Tools Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 05-19-2004, 11:13 AM   #1
PrOxLaMuS© S30
Z Car Freak (S30)
Send a message via AIM to PrOxLaMuS© S30
But here it goes.. all the info for engine swaps and wiring and codes for a 240SX...
Turbo KA24DE [more info]
Swap Difficulty: 1
Aftermarket Support: 3
Donor Car(s): S13 (1991+ US model), S14 (all US models), Hardbody (pick-up)
Stock Horsepower: 155hp (157ps) @ 5600rpm *before turbo install*
Stock Torque: 160lb/ft (22.2kgm) @ 4400rpm *before turbo install*
Redline: 7,500rpm
Good: cheap, fast, less work than a swap
Bad: reliability issues in some cases when running med/high boost sustained
Engine Cost: $800-1,500 (a few hundred more if it's rebuilt or has some parts upgraded/strengthened)
Install Cost: n/a (everything is installed other than turbo) OR $200-500 (to install a new KA where your old KA was)
Modified Horsepower Ceiling (stock internals): 250-350hp
CA18DE-T [more info]
Swap Difficulty: 4
Aftermarket Support: 4
Donor Car(s): Silvia (1989-1990) and 180sx (japan)
Stock Horsepower: 173hp (175ps) @ 6400rpm
Stock Torque: 166lb/ft (23.0kgm) @ 4000rpm
Redline: 8,500rpm
Good: higher redline and cheaper than SR20DET with about the same potential, iron block
Bad: less parts support (esp in the US), weaker head gasket than SR20DET
Engine Cost: $2,000-3,000
Install Cost: $1,000-2,000
Modified Horsepower Ceiling (stock internals): 300-400hp
SR20DE-T (S13) [more info]
Swap Difficulty: 4
Donor Car(s): Silvia K (japan), Kouki 180SX
Stock HP: 203hp (205ps) @ 6000rpm
Stock Torque: 202lb/ft (28.0kgm) @ 4000rpm
Redline: 7,500rpm
Good: great output for the price with very good potential
Bad: less output than an RB25 and weakest (stock) SR20DET, aluminum block
Engine Cost: $2,500-3,500
Modified Horsepower Ceiling (stock internals): 350-450hp
SR20DE-T (S14) [more info]
Swap Difficulty: 4
Stock Horsepower: 217hp (220ps) @ 6000rpm
Stock Torque: 202lb/ft (28.0kgm) @ 4800rpm
Redline: 7,500rpm
Good: slightly better output than the S13 SR20DET
Bad: VVT can be an issue when modifying heavily, aluminum block
Engine Cost: $4,000-5,000
Modified Horsepower Ceiling (stock internals): 350-500hp
SR20DE-T (S15) [more info]
Swap Difficulty: 4
Stock Horsepower: 247hp (250ps) @ 6400rpm
Stock Torque: 202lb/ft @ 4800rpm
Redline: 7,500rpm
Good: ~250hp stock, usually very low mileage, better condition than s13 or s14 engines (in most cases)
Bad: 6 speed tranny is somewhat weak, so if you plan to increase the hp much you want to swap it for the ka tranny or an s13/14 tranny, VVT can be an issue when modifying heavily, aluminum block
Engine Cost: $5,000-6,000
RB20DE-T [more info]
Swap Difficulty: 3
Donor Car(s): Skyline R31
Stock Horsepower: 207hp (210ps) @ 5600rpm
Stock Torque: 180lb/ft (25.0kgm) @ 4000rpm
Redline: 8,000rpm
Good: deeper engine sound, stronger than the SR20DET, more stock horsepower, iron block
Bad: cost
Engine Cost: $2,500-3,000
Install Cost: $2,000-2,500
Aftermarket Support: Fair
Modified Horsepower Ceiling (stock internals): 400-450hp
RB25DE-T [more info]
Swap Difficulty: 3
Donor Car(s): Skyline GT-S (R32, R33, R34)
Stock Horsepower: 247hp (250ps) @ 6000rpm
Stock Torque: 217lb/ft (30kgm) @ 4800rpm
Redline: 8,000rpm
Bad: cost, replacement parts availability
Engine Cost: $5,000-6,500
Install Cost: $2,500-3,000
RB26DE-TT [more info]
Swap Difficulty: 2
Donor Car(s): Skyline GTR (R32,R33,R34)
Stock Horsepower: 316hp (320ps) @ 6800rpm
Stock Torque: 289lb/ft (40.0kgm) @ 4400rpm
Redline: 8,000rpm
Good: huge potential, high horsepower stock, iron block
Bad: AWD tranny can't be used without lots of modification and custom work. TT setup can be retained, but it's much easier to convert it to a single turbo. RB25 tranny (5 speed rather than RB26 6 speed) because of clearence and fit issues.
Engine Cost: $7,000-8,000
Install Cost: ~$3,000 (AWD and TT setup will be in excess of $15,000 for install)
Modified Horsepower Ceiling (stock internals): 500-600hp
RB30DE-T (hybrid) [more info | head conversion how-to]
Swap Difficulty: 3
Donor Car(s): Australian (block; RB30ET 3.0L SOHC) / Skyline GTR or GTS-T (head; RB25, RB26, or RB20)
Stock Horsepower: ?hp (?ps) @ ???rpm
Stock Torque: ?lb/ft (?kgm) @ ???rpm
Redline:
Good: good potential, iron block, cheap engine, when modified produces large hp numbers at low revs
Bad: age, replacement parts availability, block is hard to find, RB20 head requires lots of work to fit correctly
Engine Cost: n/a
Install Cost: ~3,000
Modified Horsepower Ceiling (stock internals): 350-400hp
VG30DE-TT [more info]
Swap Difficulty: 3
Donor Car(s): 300ZX TT
Stock Horsepower: 300hp (304ps) @ 6400rpm
Stock Torque: 283lb/ft (39.3kgm) @ 3600rpm
Redline:
Good: very unique and a decent engine for heavy modification
Bad: huge cost for custom fabrication
Engine Cost: $4,000-6,000
Install Cost: $10,000-20,000+
Modified Horsepower Ceiling (stock internals): 450-550hp
VQ30DE(K) [more info]
Swap Difficulty: 2
Donor Car(s): VQ30DE in A32 Maxima(1995-1999 US model), VQ30DEK in A33 Maxima(2000-2001 US models)
Stock Horsepower: 190 hp @ 5600 rpm(A32 VQ30DE), 222hp @ 6400rpm(A33 VQ30DEK)
Stock Torque: 205 lb ft @ 4000 rpm(A32 VQ30DE), 217 lb ft @ 4000rpm(A33 VQ30DEK)
Redline: 8,000 rpm
Good: Can be cheap, good low-end, lightweight, very turbo friendly for an NA motor.
Bad: Aluminum block, lack of top end on non DEK motors. Note: Can be fixed with variable intake manifold from Courtesy Nissan. Needs Pathfinder tranny.
Engine Cost: $400+
Install Cost: N/A
VQ35DE [more info]
Swap Difficulty: 2
Aftermarket Support: 2
Donor Car(s): 350Z, G35, kouki Maxima, kouki Altima, kouki Pathfinder
Stock Horsepower: 287hp (291ps) @ 6,200rpm (350z/G35), 245hp (249ps) @ 5,800rpm (Altima)
Stock Torque: 274lb/ft (38.0kgm) @ 4,800rpm (350z/G35), 246lb/ft (34.2kgm) @ 4,400rpm (Altima)
Redline: 6,600rpm
Bad: huge cost for custom fabrication, engine taken from a kouki Altima or Maxima will need a RWD trans
Engine Cost: $5,000-7,500
Modified Horsepower Ceiling (stock internals): n/a (350-400hp est.)
PrOxLaMuS© S30 is offline   Reply With Quote
Old 05-19-2004, 11:14 AM   #2
PrOxLaMuS© S30
Z Car Freak (S30)
http://www.zilvia.net/faqs/faqs.asp
- Scanned Parts Catalog in GIF Format
- Scanned Factory Service Manuals in PDF format
- Wiring Diagrams
http://www.srswap.com/ (Really good site , Lots of info n Picture)
- Look in (SR Install FAQ )
Which SR20DET to buy?
How much does it cost?
What parts are needed?
Step-by-Step Install Guide
Payment & Shipping info
Wiring Information
Auto Manual transmission swap
Trouble Shooting Guide
Old FAQ Here Parts
Cross Reference
MAF Wiring Charts
Ignitor Wiring Charts
Factory Service Manual FSM - All 240SX model (175mb file)
http://www.neteasier.com/240sxfsm.zip
S13 & S14 Nissan parts catalog
http://www.ctech.ca/npclub/s13parts/
http://www.ctech.ca/npclub/s14parts/
Specs of 240SX (s13 and s14)
I'am updating the link of Develish..
S13
http://forums.neo240sx.ca/viewforum.php?f=7
S14
http://forums.neo240sx.ca/viewforum.php?f=8
sr20det ECU pinout From tru on npclub
1 Coil pack 1 output (via power transistor Unit)
2 Coil pack 2 output (via power transistor Unit)
3 Tachometer signal output
4 ECCS relay
5 Ignition pulse monitor (for trip comp ?)
6 Ignition Signal Ground
7 RX data (signal from Nissan Consult hand terminal)
8 Coil pack 3 output (via power transistor Unit)
9 Coil pack 4 output (via power transistor Unit)
10 -
11 -
12 A/T signal DT3 (autotrans gear select ?)
13 Ignition Signal Ground
14 CLK clock (timing signal) ?
15 TX data (signal to Nissan Consult hand terminal)
16 AFM Signal input (air flow meter)
17 AFM ground
18 Water temp sensor input
19 Oxygen Sensor input (O2)
20 TPS input (throttle position sensor)
21 Sensor ground
22 CAS 180deg signal (crank angle sensor)
23 CHK check (check start) ?
24 Monitor check lamp (Red) (fault code lamp output)
25 Exhaust over temp warning lamp output
26 Exhaust temp sensor input (behind the Cat)
27 Detonation sensor input (knock sensor)
28 TPS for A/T (kick down switch)
29 Sensor ground
30 CAS 180deg signal (crank angle sensor)
31 CAS 1deg signal (crank angle sensor)
32 Speed sensor input
33 -
34 START signal (from ignition switch)
35 A/T neutral switch input
36 IGN (ignition ON, from ignition switch)
37 TPS power output (power to throttle position sensor)
38 ECCS power
39 ECCS ground
40 CAS 1deg signal (crank angle sensor)
41 A/C on input (Air Con ON from A/C panel or climate control)
42 A/T signal DT1 (auto trans gear select ?)
43 Power steering switch (speed proportional control output)
44 A/T signal DT1 (auto trans gear select ?)
45 Ambient air temp sensor input
46 ECCS backup power
47 ECCS power
48 ECCS ground
101 Injector No 1 drive output
102 EAI control solenoid output (EGR valve control ?)
103 Injector No 3 drive output
104 Fuel pump relay output
105 Fuel pressure control module
106 A/C on output (Air Conditioner on relay signal)
107 Injector ground
108 Injector ground
109 Reverse electrical flow return circuit (alternator fail input ?)
110 Injector No 2 drive output
111 Turbo boost pressure control solenoid (over boost cut ?)
112 Injector No 4 drive output
113 AAC valve control (Auxiliary Air Control, idle speed control)
114 -
115 -
116 Injector ground
ca18det ECU pinout From tru on npclub
ECU PINS - Description of use
1 - Coil pack 1 output (via power transistor Unit)
2 - Coil pack 2 output (via power transistor Unit)
3 - Coil pack 3 output (via power transistor Unit)
5 - Boost pressure control solenoid (domestic Japanese cars only, not Euro models)
6 - Air conditioner relay
7 - Tacho drive output to tachometer
8 - Variable intake butterfly control solenoid (domestic Japanese cars only, not Euro models)
10 - Ground
11 - Coil pack 4 output (via power transistor Unit)
16 - ECCS system relay (earth = on)
17 - Injector pulse duty output (to trip computer for fuel usage measurement)
18 - Fuel pump relay (earth = on)
20 - Ground
23 - Knock sensor input
26 - Air flow meter pin B (ground ?)
27 - Air flow meter pin A
28 - Coolant temp sensor input
29 - Oxygen sensor input (unleaded catalyzer model only)
30 - Sensor earth
32 - Check lamp output to check connector (green)
33 - Check lamp output to check connector (red)
37 - Air flow meter pin D (non cat models ? )
38 - Throttle Position Sensor potentiometer (wiper)
41 - Crank angle sensor 180 deg input
42 - Crank angle sensor 1 deg input
43 - start signal (cranking) from ignition switch
44 - Neutral(manual) / park(auto) gearbox switch signal
45 - Ignition On switch signal
46 - Air conditioner thermostat input (ECU controls AC activation)
47 - To check connector ?????
48 - TPS potentiometer battery output (5 volt?)
49 - Battery from ECCS relay
50 - Ground
51 - Crank angle sensor 180 deg input
52 - Crank angle sensor 1 deg input
53 - Speed sensor input via the speedometer
54 - TPS switch (throttle idle position)
55 - Ambient air temp sensor input (sensor is in front of radiator)
56 - ?????
57 - TPS switch (full throttle position)Auto trans? (kick down switch)
58 - battery, unswitched
59 - battery from ECCS relay
60 - Ground
101 - Injector No 1 drive output
103 - Injector No 3 drive output
106 - AAC (aux/idle air control) valve output
107 - Injector drive ground
108 - Injector drive ground
109 - Battery from ECCS relay
110 - Injector No 2 drive output
111 - ? CA18DET A/T ? or pressure reg control valve?
112 - Injector No 4 drive output
115 - Heater output for O2 sensor (unleaded catalyzer model only)
116 - Injector drive ground
240sx brake upgrade SPECS
http://www.npclub.com/bb/showthread...=&threadid=8001
Reading the fault codes on your CA18DET ECU
http://www.npclub.com/bb/showthread...=&threadid=8074
300ZX (Z32) brake conversion for 240SX
http://www.npclub.com/bb/showthread...=&threadid=6665
S13 Silvia Front End Conversion info
http://sr20.hybrids.jp/installations/silvia_front/
ECU Wiring Diagram for 240SX 91-92-93
http://www.ctech.ca/npclub/npclub/r...ecu-diagram.jpg
How-To do a Self test KA24DE ECU diagnostic (french)
http://www.npclub.com/bb/showthread...=&threadid=4548
Old 05-19-2004, 11:15 AM   #3
PrOxLaMuS© S30
Z Car Freak (S30)
Some little info on the KA...
http://www.unstable-hybrids.com/FAQ_KA.htm
KA24DE Turbo
http://www.back-yard-productions.com/CONROY.htm
Nissan Engine Info...
http://sr20det.nismo.org/nissanengines.htm
More KA24DE Turbos...
http://www.socal240sx.org/articles/superstreet0801.html
SR20 FAQ's
http://srswap.com/faq2.htm
http://srswap.com/faq.htm
Auto-Manual Tranny swap (especially the wiring).
Plus other excellent info on KA24DE/KA24DET, brake swap, VLSD swap, hacked MAF.......etc
http://www.ka24development.com/index.html
Old 05-19-2004, 11:24 AM   #4
MrodDrft
Dorifto Pic King
MrodDrft's Avatar
Send a message via AIM to MrodDrft
Thats some GREAT info but im just wondering how is it easier to swap in a RB26dett than to swap an sr20 ?
MrodDrft is offline   Reply With Quote
Old 03-23-2006, 02:22 AM   #5
killab18
yea also on your scale its easier to drop in the vq35de in the 240??? you might need to change your difficulty ratings. But damn good info reguardless.
killab18 is offline   Reply With Quote
Old 03-23-2006, 09:13 PM   #6
metalmulishaS14
metalmulishaS14's Avatar
ALright, I have a 1993 240sx, with an s13 sr20det. How hard would it be to put an S14 sr20 in it? Im thinking of buying the whole front clips, so that may help... thanks
Metalmulisha
metalmulishaS14 is offline   Reply With Quote
Old 03-24-2006, 03:45 PM   #7
blk90s13
Send a message via AIM to blk90s13
great info
blk90s13 is offline   Reply With Quote
Old 03-24-2006, 05:17 PM   #8
new_to_drift
another 240 owner
none of the links work.
Old 03-24-2006, 07:06 PM   #9
dreamdrivedrift
well they were posted two years ago.
dreamdrivedrift is offline   Reply With Quote
